tranny problems
Old 10-02-2008, 07:54 AM
HankL's Avatar
HankL
HankL is offline
sorry to hear about the 1996 Ram auto trans problem
in addition to the good advice given above
consider:
there have been past posts that the 1994 to 1996 46RH/46RE
had defective D-ring seals on some of the internal pistons
that give excessive leakage as they get old
and this shows up as some limited shifting when 'dead cold'
that get worse and worse as the ATF warms up
there are other 46RH/46RE
inherent problems listed at this helpful website:
http://www.specialtytrans.com/specia...sler_index.htm
http://www.sonnax.com/announcements/SC-46-47RHE.pdf
as cheap 'band aids'
you might try
a new filter,
8 quarts fresh ATF+3,
and a bottle of Lubegard Red Bottle from a NAPA store
{about a $100 bet on 'good luck' for your part}
but the odds are
your auto trans needs a rebuild
hope you have good luck rather than bad
Old 10-02-2008, 08:00 AM
scdodgeram96's Avatar
scdodgeram96
scdodgeram96 is offline
ok i wil try that and see what happens the magnet had black liquid metal shavings but not a whole lot and thanks hankl i hope i have good luck too
Old 10-02-2008, 06:36 PM
scdodgeram96
going up
Old 10-02-2008, 06:46 PM
dodgeguy97's Avatar
dodgeguy97
dodgeguy97 is offline
replace both of your pressure transducer soleniods and your 2-3 shift spring while in there www.performancetransmissions&parts.com and put atf+4 back in
Old 10-06-2008, 08:59 PM
scdodgeram96
ok well i changed the filter and fluid and got it working pretty good it pulls good now even when its warm and it shifts good the problem is now u have to put it in 1st then shift it manualy then when u stop u have to put it in nuetral then back in 1st if u just put it in drive it feels like its taking off in second gear does anyone know why its doing this? it will not downshift and when u stop and put it in 1st it still like taking off in second gear u have to put it in nuetral then back into 1st plz let me know thanks
Old 10-07-2008, 06:35 AM
MonteC's Avatar
MonteC
MonteC is offline
Adjust your cable and then try replacing the governor presser sensor and solenoid.
Old 10-07-2008, 06:38 AM
MonteC's Avatar
MonteC
MonteC is offline
Ok, this is the second time ive seen you bring this up. Do you know what part you are talking about? If you are talking about the part i think you are talking about then calling it a 2-3 shift spring is wrong, and you are misleading people. If you really are talking about the 2-3 shift spring then you are crazy, they dont break.
Please clarify what you are talking about.
Old 10-07-2008, 05:27 PM
scdodgeram96
ok where is the govener presser sensor located?
Old 10-07-2008, 07:35 PM
MonteC's Avatar
MonteC
MonteC is offline
On the valvebody.
Old 10-12-2008, 07:56 PM
scdodgeram96
ok i need help one more time does anyone know where the sensor is located on the tranny that runs the speedometer
Quick Reply: tranny problems
