Installing a Flowmaster Super 44
Old 10-04-2008, 02:27 AM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
Question Installing a Flowmaster Super 44
Does anyone have any suggestions...recommendations...measurements or ANYTHING on install a Flowmaster Super 44 on a 1998 Dodge Ram 1500 4x4?
I will be installing from a stock muffler to the super 44...how much extended pipe will I need? What about having the exhaust exit prior to the rear tire? Any input? Picture? anything?
Please let me know...I plan to do this real soon...already have the muffler...didn't want to pay the $100-150 labor cost...plus its a muffler...how hard could it be?
Old 10-04-2008, 03:08 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
If you have a welder, or a method of cutting the pipe and using clamps, it shouldn't be that hard. But some of us here aren't that lucky.
The muffler my shop used was a FLO-942546. It is approximately 19" in length (overall) from inlet to outlet, with the case itself being 13" long, 4" thick, and 9.75" wide. Its designed for a 2.5" pipe, inlet and outlet.
Let me see if I can dig up any of the old pictures of the setup.
EDIT: Couldn't find the pics, and its night, so I can't take any decent ones right now. Will do so this weekend. I did measure, however, and there is an approximately 18" or so piece of steel pipe they installed after the muffler to my existing exit pipe. The front of the pipe has been welded to the old exhaust pipe in front of it (going to my Magnaflow cat).
I had forgotten just how big that stock muffler was.
Old 10-04-2008, 07:25 AM
lastrights's Avatar
lastrights
lastrights is offline
All i can say is your going to be in wow mode , because your going from stock , to something with sound lol!!!! Vvvvvrrrmmmmmmmmmmm
Old 10-04-2008, 11:16 AM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
Yea I excited...my wife gonna be pissed! My other rig she normally drives is broken so she temporary driving my truck.
Maybe I should fix that one first? Nah hunting season has started and I go up with my buddies next weekend!
My buddy has a diamond pipe cutter and 3 welds....we should be ok.
Thanks for any more comments and pics!
Old 10-04-2008, 01:09 PM
EricCartman's Avatar
EricCartman
EricCartman is offline
If you have to have any tube bent... I would recommend having a shop do it. They will bent it correctly using a mandrel bender so that the pipe doesn't kink and it is smooth on the inside.
Good luck,
Cartman
Old 10-04-2008, 06:48 PM
hometheaterman's Avatar
hometheaterman
hometheaterman is offline
That might not be the best for hunting season as it is loud. You don't want to scare everything off. I have a buddy that has a Toyota and puts his stock exhaust on for hunting season and runs a loud on the other times. I myself just run the FM 40 all the time.
Old 10-04-2008, 08:06 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
my stock muffler was 38" in length.
Old 10-04-2008, 10:19 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Yeah, 18" + 19" = 37", and they were approximates, so I bet you my stock muffler was 38" too.
Old 10-05-2008, 12:44 AM
TIMIDONE's Avatar
TIMIDONE
TIMIDONE is offline
I measured 40" on mine..close enough! The muffler noise during hunting...I believe they are use to trucks...plus I'm not road hunting. I pull off and usually walk 2-3 miles in and wait 1 hr before commencing.
Is there a way I put it on without welding for time being? In the end it will be welded but I want to get it on in a hurry...test it and if all good weld or then just take it off. Ideas?
Old 10-05-2008, 01:21 AM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
just use clamps.
Quick Reply: Installing a Flowmaster Super 44
