almost there
Old 11-18-2008, 09:10 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
you'll note too that the old LA performance heads only flow just slightly better than the stock magnum heads, which is why the LA guys like to throw them one their engines. They can get a cheap set of rebuilt magnum heads for much cheaper than the 2.02 LA heads.
  #22
Old 11-18-2008, 10:12 PM
BlueBeast2's Avatar
BlueBeast2
BlueBeast2 is offline
heres a link I got from pc http://www.pavementsucks.com/tech/rollerrocker.php its a step by step install of a set of rr's. I agree if your getting the non adj. you can just throw them on according to that write up. I have come to the conclusion that for stock use th 1.7's and if you upgrade your cam use the 1'6's. Thats why i'm getting the 1.6's cause my cam's lift is already 512
  #23
Old 11-18-2008, 11:19 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
That write up is not exactly accurate I found, but it gives you the gist of it.
  #24
Old 11-18-2008, 11:24 PM
BlueBeast2's Avatar
BlueBeast2
I didn't really read too much of it beings I wasn't sure what I was getting. I figured it would be helpful :shrug:
  #25
Old 11-19-2008, 04:39 AM
talon6's Avatar
talon6
talon6 is offline
i found that write-up when i googled the rockers,but with the link,(thank you)i wont have to google it again.i know i can do the swap myself,but for a 100$ its hard to refuse.
yes,i am getting the non adj. trying to keep it real simple.
heads,hmmm now you got me thinkin.lol
thanks silver and bcdalton for your first hand report.you guys pretty much said everything i wanted to hear about the performance gains.
bcdalton,i also tried the hypertech max energy first,and now the 3815.and after i get these couple more things done,i will be getting the sct.just donnt want to get it, then have to turn around and have it reprogrammed for things i add.
