Preserve your doors!
Old Nov 17, 2008 | 04:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default Preserve your doors!
For any one that is interested, if your doors are not rotted yet or are just barely starting to do so. Take the interior panels off and pour some oil down into the bottom of the door into the seam where they rot from the inside out. It will make them last longer.
Old Nov 17, 2008 | 05:07 PM
ophidia's Avatar
ophidia
Just motor oil? Sounds like it would work.
Old Nov 17, 2008 | 08:40 PM
95 Jamin Ram's Avatar
95 Jamin Ram
When i fixed my door rust someone on here told me to clean out my doors very good and spray rubber undercoating down there so far it has been working
Old Nov 17, 2008 | 08:49 PM
pcfixerpro's Avatar
pcfixerpro
lol... what do you perfer 10w30 10w40 20w50 coventional, synthetic? Just messing with ya.
Old Nov 17, 2008 | 09:02 PM
ophidia's Avatar
ophidia
I prefer Amsoil with a little Mobil 1 chaser :
Old Nov 17, 2008 | 09:09 PM
jmhai's Avatar
jmhai
Do the doors rust because the drain holes get plugged up with curd...and if so wouldn't spraying the liner stuff plug them too.
Old Nov 17, 2008 | 09:10 PM
dodgeram07's Avatar
dodgeram07
i poured some "end rust" stuff down into the doors and drilled some wholes... it's working good for now.
Old Nov 17, 2008 | 09:26 PM
98DodgeRam1500's Avatar
98DodgeRam1500
I used a rustoleum type of rust converter to stop any rust that was there, then I used caulking and put a generous bead between the panels from front to back, then used some spray undercoating liberally.
so far its stopped the spreading.
Old Nov 18, 2008 | 05:46 AM
zman17's Avatar
zman17
The undercoating works too, and after it dries you still use the motor oil every so often. And btw you can use the waste oil from your oil changes.
And they don't rot because the holes get clogged, they rot because it's a bad design and the water never gets to the drain hole .
Old Nov 18, 2008 | 11:16 AM
guitarking135's Avatar
guitarking135
They rust for the same reason chevy's cab corners rust... combination of poor design and crappy material there's really nothing that can stop it because they rust from the inside out. while bedliners and stuff like that will help prolong it it is inevitable they will rust. I got my 99 and I was a little upset about the amount of rust on the doors mainly the drivers side I can see the gasket at the bottom but you know haveing a dad that does the best body work in town and being a painter yourself kinda has its advantages so yea patch panels
