Best Cold Air Intake????
Old Feb 11, 2005 | 01:06 PM
steve05ram360's Avatar
steve05ram360
Default RE: Best Cold Air Intake????
dont do it!!! you might as well have no heat shield... that design will still suck in hot engine compartment air, you need a shield
Fabing up a heat shield should be easy, get some thick sheet metal and cut it to the size you need, then insualate it so it looks better and will not heat soak. insulate your intake tube as well (applies to metal ones only) so it doesnt get heat soaked either.
Old Feb 12, 2005 | 10:51 AM
charlie1935's Avatar
charlie1935
Check out ramairbox.com
Old Feb 12, 2005 | 10:54 AM
moparmania's Avatar
moparmania
hey steveo. do you think you could post a pic or 2 of your set up. it would give me some better ideas for a sheild. i run the mac intake without one , and i would like to make a sheild for it. thanks
Old Feb 12, 2005 | 02:31 PM
steve05ram360
Sure, I have some pics at work so it'll have to wait until Monday...
Old Feb 12, 2005 | 07:03 PM
moparmania's Avatar
moparmania
THANKS MAN ILL POST A FEW OF MY SETUP AND MAYBE I CAN FIGURE SOMETHING POSSATIVE OUT
Old Feb 12, 2005 | 10:58 PM
moparmania's Avatar
moparmania
hers a few pics of the current setup.
[IMG]local://upfiles/6094/A748F1B72BC04FB48A7C7AEDDDDFDC7A.jpg[/IMG]
[IMG]local://upfiles/6094/24D63606CB2740DC91535FD7A8C3EA07.jpg[/IMG]
Old Feb 13, 2005 | 02:04 PM
steve05ram360
hahaha, as luck would have it, I have a pic on my cardomain site... take a look 2000 Ram look on the last page, last pic...
not the best shot but should give you an idea before I can get to the other pics at work...
Old Feb 13, 2005 | 07:23 PM
maRdeR808's Avatar
maRdeR808
if you get the kn fipk, make sure you got some good zip ties...if you look closely, steve has one holding his to the bracket. i got one too and so does everyone else i know here that has one
Old Feb 14, 2005 | 12:51 AM
steve05ram360
actually the zip tie was for the insulation, I have a hose clamp on my bracket. I found no difference with the insulation, so I never put it back on. However if I ever get some of the adhesive backed stuff, I will add it just to make sure. the whole point was to prevent heat soak but since the tube is plastic, it doesnt matter too much.
Old Feb 14, 2005 | 01:29 AM
Grr287's Avatar
Grr287
OK.....so steve.....if I get this FIPK II can you sum up everything you said you did to yours (i.e.) not tighten too much, insulation and stuff like that? I looked at the pic of your heat shield....any directions you could give me? thanks
