Directionals wont turn off!!!
Old Nov 19, 2008 | 06:12 PM
clipper77's Avatar
clipper77
Default Directionals wont turn off!!!
hi everyone,
tried posting a similar thread but no one replied and i need help ASAP. Recently my 96 2500's directionals went on and will not turn off. The same is with my center console and plate lights (they all blink). On top of that, the truck wont start, wont even crank. Could this have something to do with my trailer tow electrical system?
Old Nov 19, 2008 | 06:24 PM
JackJ's Avatar
JackJ
Did you try disconecting the battery then hooking it back up after about 10 min? Some thing may need to be reset.
Old Nov 19, 2008 | 06:25 PM
ophidia's Avatar
ophidia
Or replacing the battery. Weak/dead batteries can do wierd-*** things.
Old Nov 19, 2008 | 07:05 PM
clipper77's Avatar
clipper77
disconnecting it doesnt help...i guess it could be a weak battery..thanks guys
Old Nov 19, 2008 | 11:22 PM
motorbrreath's Avatar
motorbrreath
you have a short causing the lights to blink like that. check all grounds, and make sure they are not broken. make sure no wires are exposed and rubbing against each other.
for the no start, check battery, cables and terminals (clean and free of corrosion) check ground going from negative to engine block, and negative to body. if the starter is good, its gonna be the battery.
Old Nov 20, 2008 | 04:34 PM
clipper77's Avatar
clipper77
ok thanks alot..sounds like il be putting most of weekend into this.
Old Nov 20, 2008 | 05:54 PM
ophidia's Avatar
ophidia
Good luck. Hopefully it's just the battery. Chasing down bad grounds is a huge pain in the ***.
Old Dec 8, 2008 | 09:51 AM
clipper77's Avatar
clipper77
After all that work, turns out the guy who had it before me installed an after market security system. When i disconnected the battery, I set it off and it cut all power to my starting system. Found the little black box under my dash by the steering column, unplugged it, and it started right up.
Old Dec 8, 2008 | 11:22 AM
charlie1935's Avatar
charlie1935
Thumbs up
Good work! Also kudoos for posting the update.
