Stalls in reverse
Old Jan 4, 2018 | 03:33 PM
  #41
On a fair few of them, replacing the crank sensor solved the issue. Get one from the dealer. Yeah, they are more expensive, but, they actually WORK. The same can't be said for the aftermarket sensors.
Old Jan 18, 2019 | 12:53 AM
  #42
Joeleen Johnston's Avatar
Joeleen Johnston
Default Can you ask your dad what the part was?
Originally Posted by ramario99
my truck had the same thing to, my dad took it to a mechanic and he replaced something by the steering wheel close to the key ignition and it got fixed. the only thing is that i dont know what they replaced there... sorry.
can you ask your dad what the part was? We’re really struggling with this issue
Old Jan 31, 2020 | 04:23 PM
  #43
Edward Randolph's Avatar
Edward Randolph
Default Reverse problem solved
Thanks guys! The crank sensor fixed my reverse issue.
I have a 2000 ram 1500 4x4 sport with the 46re tranny. I replaced my TC and reverse stopped working. I read all kinds of threads before this one, but this seemed to to the closest to my symptoms
Thanks again
Eddy
Old Feb 22, 2021 | 07:34 PM
  #44
case82's Avatar
case82
Default 1982 Dodge d150 1bbl 6Cyl
Ok I may be posting this in the wrong area. 1982 Dodge d150 1bbl 6Cyl stalls in reverse and when I stop some of the time. Just trying to figure out the issue. It starts up when I turn the key and pump the gas pedal at the same time. Is it a vacuum leak on the carb or airfilter or a some cord. I replace the throttle cord already. Thank in advance for any help.
Old Feb 22, 2021 | 08:16 PM
  #45
Yeah, you wanna be in the first gen ram section.
Old Oct 4, 2022 | 08:09 PM
  #46
Crowebird98's Avatar
Crowebird98
So my 2000 5.9l gas dodge ram stalls in reverse without it having to sit. Like when I go to back put even after being parked for an hour it'll stall. So it doesn't have to sit for extended periods of time and it has a vacuum leak when running too. I replaced my IAC, purge valves and lines and I still get the same issue. I just found that the rear rollover valve on the gas tank is melted shut so maybe that's it but I hear a lot of hissing still when I daily drive even after replacing most of the "air" parts on my engine. Any ideas?
Old Oct 4, 2022 | 08:19 PM
  #47
Find and fix the vacuum leak first. I do believe the rollover valve is still available......
