Guinea Pig: Extensive TreadWright(Retread) Tire Test Thread
Old Dec 14, 2009 | 08:51 AM
  #81
notanexit7's Avatar
notanexit7
I was going for the 265 bfg at knockoffs. I don't plan on resurrecting my truck from the grave when it goes (want a newer dodge 4x4) and I'm sure it probably won't have the same size wheels so I was just weighing my options. my tires I have now have no tread whatsoever.
Old Dec 14, 2009 | 06:39 PM
  #82
Sheriff420's Avatar
Sheriff420
i believe the bridgestone dueler knockoffs would be a better tire for highway use. they're only 72$ each in that size. and the bfg a/t are 88 for e rated an 83 for d rated.
if i were you, i would order some treadwrights. just inspect them really well when you get them. if the tread is peeling away from the tire carcass then you just need to call them and send a picture of the damage and they will send a replacement.
when i ordered mine i told them that i wanted all bfg a/t casings too, because i didn't want mis-matched sidewalls. that and the bfgs have a rim guard on them.
Old Dec 14, 2009 | 07:11 PM
  #83
talon6's Avatar
talon6
i bought a set of the bfg at knockoffs for my sons toyota (31/10.50/15), and couldnt be happier. put them on a new set of black crager soft 8 rims and 2 of the tires never even took any weight to balance them. havent put very many miles on them yet,but so far so good. i would buy them again.
Old Dec 14, 2009 | 08:49 PM
  #84
004x41500's Avatar
004x41500
i have a 2000 ram 1500 4x4 265/75-16, still them same size. dodge only used to rim sizes 16x7 and 17x9 maybe 10?(i think)
Old Dec 15, 2009 | 09:47 AM
  #85
Sheriff420's Avatar
Sheriff420
i'm pretty sure the off road rims are 17x8
Old Dec 15, 2009 | 11:45 PM
  #86
004x41500's Avatar
004x41500
im not to sure, because if it was 8 wide you couldnt fit a 33x12.50 on it thats why i thought maybe 10 wide.
Old Dec 16, 2009 | 01:42 AM
  #87
meanwhitemopar's Avatar
meanwhitemopar
i am pretty sure they are only 8inch wide. i have fit 14.50s on a 9 inch wide rim... so 12.50 on an 8 inch wide is a peice of cake... hang on.. here ya go...
Ram Rim Dimensions
1994-1999 1500 2WD/4WD Aluminum Wheels
Lug Pattern - 5 on 5.5", 1/2" bolt
Rim Size - 16x7.0"
Offset - +13.97mm
Backspace - 5"
Max Tire Size -
15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
2000-2001 1500 2WD/4WD 16" Aluminum Wheels
not posted yet
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
Lug Pattern: 5 on 5 1/2
Rim Size: 17x7"
Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels (posted to DiRT by Mat Felthousen):
Weight: 23.5 pounds
Rim Size: 17x8"
Actual width edge to edge: 9 1/16"
Backspacing: 5 9/16".
The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
offset calculate: 1 1/32"
1994-2002 2500 2WD/4WD Steel Wheels:
Lug Pattern - 8 on 6.5", 9/16" bolt
Rim Size - 16x6.5"
Offset - 4.75"
Max Tire Size - 245/75R16, 255/85R16
2000-2002 2500 2WD/4WD Forged Aluminum Wheels:
Rim Size - 16x8"
Offset - 6.25"
Max Tire Size - ??
the link ot this all is...
http://dodgeram.org/tech/specs/wheel/specs.html
Old Feb 7, 2010 | 05:10 PM
  #88
bekins01ram's Avatar
bekins01ram
after reading probably hundreds of reviews and comments about these tires I thought I'd give em a try. My 01 5.2L with the 265/75 R16 guard dog M/T's with their kedge grip. I requested all 4 matching casing with a 3-ply sidewall, and got 4 matching BFG A/T ko casings. So far they ride smooth, took a lil bit of weight it seems to balance tho. Also have a nice hum on the road. At about 45-50 mph, sounds like a semi on the freeway. Not terrible tho. Not louder than my super 44 anyway. And so far on a couple inches of loose/ packed snow, I have to really romp on it, to break em loose. Much better than the Dunlop AT20's that were on it. Only bad part is now my speedometer is off a bit im pretty sure. The stock size was 245/75, but ah well, I'll manage.
Hope these pictures work.
link:
http://img525.imageshack.us/g/sany1729.jpg/
Old Feb 7, 2010 | 06:25 PM
  #89
95RAM360's Avatar
95RAM360
alright after going through this entire thread im goig to treadwright for my tires which will be within this month. Not sure which ones i want to go with though.
I dont know if i want to get 265's again, or get the 2 1/2 level kit and get the 285's....im debating for i dont want my mpg's to drop, im getting good mpgs now so...but i have the 4.10's so it may be better
Old Feb 7, 2010 | 06:43 PM
  #90
Sheriff420's Avatar
Sheriff420
with 4.10s and 32.8" tires you should be getting 13-15, which is what you should get with 3.55 gears and 245/75/16 tires (stock).
