Oil temp not constant
Old Dec 14, 2008 | 12:40 PM
vmann's Avatar
vmann
Default Oil temp not constant
Lately my oil pressure has been going nuts. If i give it 2000 rpm's i can watch my oil pressure gage go up. Ill post a video in a bit.
Video: sorry its on rapidshare. Click free user and wait 30 seconds then click download. To view it save it and run it with windows media player
http://rapidshare.com/files/173333801/RamOil.zip.html
Old Dec 14, 2008 | 12:46 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Oil temp? You mean oil pressure?
Old Dec 14, 2008 | 12:53 PM
vmann's Avatar
vmann
my bad yes lol
Old Dec 14, 2008 | 12:55 PM
OldMoparMan's Avatar
OldMoparMan
Normal. The higher you rev the engine, the faster your oil pump turns. If it's electric, you may have a sending unit taking a dump giving you eratic readings.
15-20 at idle, and 40-60 at 2000+ is normal.
Old Dec 14, 2008 | 05:45 PM
vmann's Avatar
vmann
so completely normal? Ive never noticed it before. It starts doing this as soon as i start it up. When i rev it it moves almost as fast as my rpm's.
Old Dec 14, 2008 | 07:32 PM
aim4squirrels's Avatar
aim4squirrels
because your engine is revving. The oil pump is connected to the engine and revs with the engine, it's a simple mechanical pump designed to keep the engine lubed up, more RPMs need more lube. You're a dude, you should know you need more lube at higher RPMs.
Old Dec 14, 2008 | 07:40 PM
vmann's Avatar
vmann
now i understand. but should the oil pump that fast? Though i would have noticed it moving that fast earlier..
Old Dec 14, 2008 | 07:45 PM
cdusthockey's Avatar
cdusthockey
here read up
http://www.international-auto.com/fi...ure-gauges.cfm
Old Dec 14, 2008 | 08:49 PM
vmann's Avatar
vmann
There are other factors that affect oil pressure, though. When the oil is colder, it has a higher viscosity (it's thicker), which means it cannot slip through the bearing clearances as easily. You'll notice that oil pressure at idle is quite a bit higher when the engine is first started up.
exactly what i was looking for. It was colder outside than usual and my engine was still fairly cold. Thanks everyone
Old Dec 14, 2008 | 10:42 PM
PurplDodge's Avatar
PurplDodge
Squirrels, you're a dirty bastard, you should know its HPMs.
