Transmission identification
Old Aug 7, 2014 | 09:33 AM
  #41
Adobedude's Avatar
Adobedude
I have a Dakota R/T with a 727 in it, what transmission do I have?
Old Aug 7, 2014 | 04:09 PM
  #42
You have a 727. 3 forward gears, one revers, plus park, and neutral. That makes it a six speed.
46RH will have a locking torque converter.
Old Oct 24, 2014 | 06:32 AM
  #43
d150isbroke's Avatar
d150isbroke
Default 91 d150
Trying to figure out what transmission is in my truck its a 1991 d150, 2wd, 3speed, 318 v8. Keep getting ether A904 or A727. Have the numbers off of the side of it but i having no luck finding anywhere to run them 💩
Old Oct 24, 2014 | 02:30 PM
  #44
Need to post in the first gen ram section.
Old Feb 15, 2015 | 12:09 PM
  #45
aikoentp's Avatar
aikoentp
Is 46RH then for 4X2?
Old Feb 15, 2015 | 01:59 PM
  #46
RH is the older version of the trans, used in trucks 95 and older. (and maybe some 96 models as well) RE is newer version, features electronic governor, instead of the mechanical one found in the RH. 96 and up transmissions should be RE. Doesn't matter what's hangin' off the back of the trans.
Old Feb 16, 2015 | 08:23 AM
  #47
aikoentp's Avatar
aikoentp
I need a good part source for 46RH pressure gov. 1995. A HD upgrade would be great. All I see out there is for RE 96 up
Old Feb 16, 2015 | 10:03 AM
  #48
That's because you have a mechanical governor. The only thing you can do with that is change the springs, to either raise or lower your trans pressure/vs. RPM
Old Feb 16, 2015 | 04:58 PM
  #49
Moparite's Avatar
Moparite
Starting in 1989 the overdrive transmission was an OPTION before is became standard in later years! If you have a overdrive button on the dash somewhere it's a A500 if not a 727. Talk about hijacked thread!
http://en.wikipedia.org/wiki/TorqueFlite
Old Sep 14, 2016 | 07:38 PM
  #50
Deborah Larson's Avatar
Deborah Larson
Default 97 Ram 1500 and 98 Durango switch.
We have a 97 Ram 1500 360 auto 4x4. What is the difference between this and the transmission from a 98 Durango? What are any concerns? I believe it is a 46re and know connector to Neutral safety is different.
Thank you.
