Transmission identification
Old Mar 10, 2017 | 01:00 PM
  #61
Originally Posted by Nicholashenke
I have an 02 Dodge Ram 1500 with the 5.9 and 4x4. How do I know what transmission I have
You have the 46RE. It's the only auto that came in them.
Old Oct 7, 2017 | 08:26 PM
  #62
rusty94's Avatar
rusty94
Smile 1994 ram 2500 diesel w/automatic
how do I know what transmission I have, 47 RH or 47 RE? the vin is 1B7KF26C5RS703583 I would like to replace it but not sure how to know which one it is, also I need to replace the transfer case which says NP 241 DLD, is there only certain years that will be the same?
Old Oct 7, 2017 | 08:36 PM
  #63
Yours is an RH. 4.10 gears too. (build sheet is a wonderful thing.)
As for the t-case, any NP241 DLD out of a ram thru model year 97 will work. The manual trans t-cases had a deeper input hub.... you may or may not need to change that to hang it off the back of your auto.
Welcome to DF!
Old Oct 7, 2017 | 08:45 PM
  #64
rusty94's Avatar
rusty94
thank you for the info!!!! my trans has been slipping some then my t case exploded due to a u joint went, ugggg, so I thought as I have the tcase out might as well do the trans. again thank you!!!!
Old Oct 7, 2017 | 08:56 PM
  #65
You are welcome. I find your reasoning to be quite sound. You are going to be RIGHT THERE anyway. Might just as well deal with it.
Old Oct 25, 2017 | 08:02 AM
  #66
Ryan Vaughn's Avatar
Ryan Vaughn
Default transmission only
I'm trying to identify what transmission I have as it was in a storage shed and I got a story but want to identify what vehicles it will fit so I can sell it. this is the case # PK 52119851 AB 2770 1867
From what I have read it is a 47RE but I need to know what vehicles it will fit in? Diesel 2500>?
thanks
Old Oct 25, 2017 | 10:14 AM
  #67
Mechanical or electronic governor?
Old Oct 27, 2017 | 12:06 PM
  #68
Moparite's Avatar
Moparite
Look at post #1
https://dodgeforum.com/forum/2nd-gen...ification.html
Old Nov 3, 2017 | 05:21 PM
  #69
eschroeder's Avatar
eschroeder
Default How do i tell which transmission i have on my 1997 dodge dakota sport 5.2L v8 pick up
How do i tell which transmission i have on my 1997 dodge dakota sport 5.2L v8 pick up? the vin ASP. the is (VIN)
1B7GG 23Y 8V52 81483
Old Nov 3, 2017 | 06:53 PM
  #70
Invalid VIN
Go here, enter the correct vin, it'll tell ya what your truck came with from the factory.
