cranking fine, no start
Old Dec 26, 2008 | 02:19 PM
Kindschi's Avatar
Kindschi
Originally Posted by charlie1935
Fuel pump will run with the key in the on position, don't have to be in start position.
Caught me slipping! I meant the On Posistion but said Start... I mix my words up constantly.
If you have Spark and fuel pump kicks on I would check the airbox like APA said, something may of gotten in there. I would check the fuel pressure too, I think you can rent the tool form Autozone for that.
Also look inside yoru tailpipe, maybe someone decided to play a joke on you and stuff a rag or something in there, I did that to my friend once had him stuck for hours.... lol
Old Dec 26, 2008 | 02:32 PM
thewrench's Avatar
thewrench
before you go draining your tank, I'd removed the intake box compleatly, inspect the
throttle body and attempt to crank the truck while someone sprayed a lil starting fluid
down the TB. Also remember, just b/c u have spark does not mean it's strong enough. I delt w/ this last week in my truck , ended up be weak spark, new coil and she runs great. I was a crank/no start also.
Old Dec 26, 2008 | 04:47 PM
99Ram360's Avatar
99Ram360
Unhappy
is there any chance that something like dry gas would work, b/c of the truck living in MI?
and possible water in gas. i know its a long stretch.
what is the easiest way to drain it.
Old Dec 26, 2008 | 08:29 PM
99Ram360's Avatar
99Ram360
Thanks guys, i'll try it in the morning. I'll keep you updated.
Old Dec 26, 2008 | 09:03 PM
APA228's Avatar
APA228
If you have gas with 10% Etahnol mix you would probably not need dry gas since it is alcohol also. However that being said if you did get bad gas it has already soaked up water and will give you running problems, but I don't think you would have gotten enough to not let you start.
Try connecting another spark plug laying up on the block to one of your spark plug leads and see what the spark looks like at a plug. It is possible that the plug wires have broken down and are not conducting as they should. The primary lead itself which you tested seldom goes bad, but the actual plug wires frequently do.
Old Dec 27, 2008 | 11:14 AM
99Ram360's Avatar
99Ram360
so will spark plug wires just stop working overnight, when i haven't noticed any problems up to that date? and wouldn't i be able to get it to fire on a couple cylinders?
Thanks
P.S. when i check the fuel pressure on the fuel rail what should it be?
Old Dec 27, 2008 | 11:49 AM
thewrench's Avatar
thewrench
ABOUT 45 PSI AT THE RAIL IIRC
Did you try to start it w/ starter fluid yet?
Old Dec 27, 2008 | 01:36 PM
99Ram360's Avatar
99Ram360
i disconnected the intake and sprayed starting fluid and nothing changed, so i took a spark plug out so i could see if it had spark and the quality of the spark, and it had spark, as for the quality of the spark it seemed fine but i really didn't know what to look for. so if you could give me a description of a good spark?
Old Dec 27, 2008 | 01:38 PM
99Ram360's Avatar
99Ram360
the spark was bright blue/white
Old Dec 27, 2008 | 01:47 PM
99Ram360's Avatar
99Ram360
crank sensor, how to test, ohm meter?
