rebuilding it myself
Old Dec 27, 2008 | 03:55 PM
JimkDaAdtman's Avatar
JimkDaAdtman
Default rebuilding it myself
Ok.. I'm not a big transmission guy, I know a lot of stuff about cars, but never really done much transmission work, so I don't know what all is included in rebuild kits, and what they are talking about with this description:
THESE ARE COMPLETE KITS WHICH INCLUDES, MOLDED GASKETS, SEALS, CHECK *****, SPEEDO SEALS, ORINGS, CONVERTER BOLTS, RINGS,3 POINT WASHERS, OUTPUT RACE, ALL NECESSARY GASKETS AND ORINGS, OIL SEALS,FILTER, DIRECT CLUTCH FRICTION, FRICTION FRONT CLUTCH, CLUTCH FRICTION, ALL REQUIRED STEELS.
EACH KIT CONTAINS 100% AUTHENTIC MOPAR PARTS AND COMPONENTS RIGHT DOWN TO SEALS AND HARDWARE. EVERYTHING YOU NEED IS IN ONE BOX. NO MORE CALLING AROUND LOOKING FOR THE RIGHT INSTALLATION KITS OR GASKETS PACKAGES. '
Here is a link to the listing, with some pics, maybe someone can tell me more about this.. http://cgi.ebay.com/ebaymotors/MOPAR...Q5fAccessories
Is this what I need to rebuild my trany myself, what if my gears are stripped? will this have everything, or do I need to just try to get one already rebuilt?
I am hoping the gears are all ok, and it's just the bands that are screwed up.. but I wont know till I tear it open... I just like to get as much info as I can before I get started.. I don't like surprises...
JimK
Old Dec 27, 2008 | 05:08 PM
vmann's Avatar
vmann
beware of china products.
Old Dec 27, 2008 | 05:14 PM
JimkDaAdtman
yeah, this says it's genuine MOPAR parts, so that would lead me to believe it's not china products.. but keep in mind, much of waht you get on all cars and trucks are made in China.. unless you buy Honda, then most is made here in Ohio.. go figure...
ALthough the Honda Fit is a chinese made car, regardless of what the anti china folks try to say..
I know, I work closely with some of the people in Honda that know..
JimK
Old Dec 27, 2008 | 05:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
PM MonteC, I know he loves to answer 100's of PM's .
Old Dec 27, 2008 | 06:03 PM
APA228's Avatar
APA228
This kit looks like seals and clutches only. If your gears are screwed up you are on your own. It does not show any bearings or gears in it and I did not see a pan gasket listed either.
Old Dec 27, 2008 | 09:26 PM
dodgeram07's Avatar
dodgeram07
you may want to put one of these in to.. http://www.transmissionpartsusa.com/...-54931ahd2.htm
Old Dec 27, 2008 | 09:41 PM
dhvaughan's Avatar
dhvaughan
the link above is to Steve White Motors, who is a legitimate Dodge dealer in north carolina. he sells autos and parts on ebay.
+1 on ask MonteC and/or Rabbler.
Monte often bad mouths the original factory mopar transmission component parts. i don't know what he thinks about mopar service parts. we'll find out soon....
Old Dec 27, 2008 | 10:39 PM
zman17's Avatar
zman17
He doesn't like them because those are the parts that are part of the problem with the trans to begin with.
Old Dec 28, 2008 | 09:55 AM
Gav1n8's Avatar
Gav1n8
I like this one...
Old Dec 28, 2008 | 04:35 PM
mrcribbs's Avatar
mrcribbs
Originally Posted by Gav1n8
I like this one...
Wow... they have a lot of nice parts for nice prices.
My trans is acting up too. I'm also considering rebuilding it myself.
Not to thread jack but my trans works fine until it warms up then I only have 1st and reverse... anything special I should check before tearing it out. (I just did a fluid / filter change and adjusted the bands but it did not fix the problem... yes I used ATF +4 also)
