Old Aug 13, 2015, 08:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Just got cab lights.. no idea how to install
Old Jan 2, 2009 | 12:36 AM
  #21
EricCartman's Avatar
EricCartman
If those are incadecent bulbs (which I assume they are) you should use a relay if you are going to tie them into your parking lights.
You might want to look at getting some LED replacment bulbs for those. I got some at www.superbrightleds.com.
If you dig through a couple of the sticky threads at the top of the forum, you should be able to find the "Merry Christmas" thread that has a link to the 2001 FSM. It will help you figure out what color the wire is.
Good Luck,
Cartman
Old Jan 2, 2009 | 12:41 AM
  #22
mjackson92rs's Avatar
mjackson92rs
Good Luck,
Cartman
Agreed. You should use a relay with the incandescent bulbs.
Old Jan 2, 2009 | 09:51 AM
  #23
vmann's Avatar
vmann
Originally Posted by mjackson92rs
To use the running lights as a switch, you need to either look up the color of the wire or use a diagnostic tool such as a DMM or test light to determine the wire you need. You can then tap into that wire for power. This will replace the wire that you ran from your battery to your switch and will give power to your cab lights when the parking lights are turned on.
ok so insted of running that wire from the battery run it from one of the wires that controls my lights. Ill look at the merry christmas thread for help on the wire color. As of now i am a little paranoid about catching my truck on fire because i had a fuse catch on fire yesterday.. And why would i want to run another type of bulb? looked on the super white site and didnt see much of anything that would help me
Old Jan 2, 2009 | 11:18 AM
  #24
zman17's Avatar
zman17
Retired Moderator - RIP
Did you look to see if the wiring was already there in one of the pillars? The wire you are looking for out the headlight switch is black with yellow tracer.
Old Jan 2, 2009 | 11:23 AM
  #25
Rex-TheDOGG's Avatar
Rex-TheDOGG
If you want to wire them up correctly, look at the following pages in the Service Manual from the Merry Christmas thread:
8W-50-3
8W-50-7
8W-50-8
8W-90-24
You do not need to use a relay for the cab lights as they do not draw enough current. Note that the parking light circuit requires a 20A fuse though. If you want the lights to be as bright as possible, then wire up a ground harness and ground it to G302 as shown. If you just rely on the cab sheet metal, the grounds may degrade over time. Post pics of your install when finished.
Old Jan 2, 2009 | 11:38 AM
  #26
zman17's Avatar
zman17
Old Jan 2, 2009 | 02:44 PM
  #27
vmann's Avatar
vmann
im going to pop off my light switch and look for the yellow wire. I didnt see any wires in the pillars. And what yall are talking about is cutting part of the wire from the lights and attaching another wire to it and ground it somewhere else? In the diagram it shows g302 is right in the middle... if i run a wire right from the middle i would have to run a pretty long cable to ground off something other than the roof metal.
Old Jan 2, 2009 | 02:50 PM
  #28
punkrguy's Avatar
punkrguy
While were on this subject (dont mean to hijack) but does anyone know if our cab lights have to be that amber color?
Old Jan 2, 2009 | 02:51 PM
  #29
vmann's Avatar
vmann
mine are clear lights. but they look amber because of the lenses.
Old Jan 2, 2009 | 02:54 PM
  #30
Rex-TheDOGG
Yes, DOT rules.
