Transmission Fluid
Old Jan 11, 2009 | 01:35 PM
  #31
zman17's Avatar
zman17
Retired Moderator - RIP
The wix ones are cork and I've never had a prob. 13ft lbs or 150 inch lbs.
Old Jan 11, 2009 | 01:59 PM
  #32
BlueBeast2's Avatar
BlueBeast2
I'm all about using rubbers
Old Jan 11, 2009 | 02:03 PM
  #33
zman17's Avatar
zman17
They leak too! LOL
Old Jan 11, 2009 | 03:14 PM
  #34
MonteC's Avatar
MonteC
Best gasket to use is a FARPAK, its a paper lament combination. Also you may need to dab a little rtv onto the threads of each bolt. DO NOT RTV THE PAN GASKET.
Old Jan 11, 2009 | 05:11 PM
  #35
zman17's Avatar
zman17
Are the holes in the gasket small enough so you can screw all the bolts into the gasket?
Old Jan 11, 2009 | 06:11 PM
  #36
MonteC's Avatar
MonteC
Nope. But the gasket is always flat packed, so they are very easy to install. They are the only pan gasket i will use. Unless the stock bonded metal one is still in good shape.
Torque pan gaskets to 100inlbs. You dont want to pinch the gasket.
With the paper lament gaskets you have to clean the gasket surfaces, just wipe them dry. When they get hot the lament takes effect.
Old Jan 11, 2009 | 06:23 PM
  #37
zman17's Avatar
zman17
Thanks M, I'm changing that crappy Help! drain plug ASAP, so I might as well try a new gasket too.
Old Jan 11, 2009 | 07:07 PM
  #38
dhvaughan's Avatar
dhvaughan
what's wrong with the plug, you just put it on this morning.
Old Jan 11, 2009 | 08:01 PM
  #39
PurplDodge's Avatar
PurplDodge
I'm still staring at it in the catalog.
Old Jan 11, 2009 | 10:32 PM
  #40
theviper90210's Avatar
theviper90210
Thanks for the reply's guys regarding the gasket
MonteC where can I get a FARPAK 46re pan gasket I cant really find them on the net
