surge at idle
Old Jan 9, 2009 | 02:02 AM
dakotas ram's Avatar
dakotas ram
Default surge at idle
it doesnt do it when 1st fired up, but after its warmed up and idling in park it surges from 850k -100k area.......runs great otherwise just annoying....IAC?
Old Jan 9, 2009 | 06:20 AM
JBs DAK's Avatar
JBs DAK
Yep,.. Take it off, clean it, good to go.
Old Jan 9, 2009 | 11:10 AM
Ram2K1's Avatar
Ram2K1
+1...and if that doesn't do the trick check the TPS.
EDIT: 1,000 posts... Nice
Old Jan 9, 2009 | 01:58 PM
dakotas ram
well i just had my whole tb apart and cleaned....
Old Jan 9, 2009 | 02:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Obviously that didn't help,so I guess you need to replace them and see what happens.
Old Jan 9, 2009 | 02:19 PM
dakotas ram
well, it didnt do it b4....whats a good way to check each?
Old Jan 9, 2009 | 05:12 PM
ophidia's Avatar
ophidia
It seems that whenever I've cleaned an IAC I've killed it. I don't know if I accidentally push them in or nuke them with cleaner, but they never seem to work right. Your best bet would just be to replace it, IMHO.
Old Jan 9, 2009 | 05:16 PM
zman17's Avatar
zman17
+1....to ophidia's reply
Old Jan 9, 2009 | 05:19 PM
360magnumram's Avatar
360magnumram
Where is the IAC valve located? could someone post a pic or something cause I've never dealt with them b4 and was curious of how to clean it.
Old Jan 9, 2009 | 05:26 PM
ophidia's Avatar
ophidia
The wire that plugs into the back of the throttle body hooks up to it (firewall side). It's held in by two T-25 torx screws. Very easy to replace.
