Ball Joints?
Old Jan 13, 2009 | 09:07 AM
WTL's Avatar
WTL
I just did mine, the ball joints werent as tough to press out as reported on here. I think its a truck by truck thing. I actually had more trouble replacing the front shock on 1 side.
Get the 23 peice kit that is specified in one of the write ups. Search Hankls posts, he has one that explains the press kit situation.,
Old Jan 13, 2009 | 09:16 AM
olyelr's Avatar
olyelr
Originally Posted by dblj16380
The main problem I had with mine was getting them to start in straight on a piece that does not have a parralel top and bottom.
Did you have a ball joint press? The setup I rented had one cup with a taper on it just for that problem. Made it fairly easy. I nearly taped one entirely in place with some weak blows with a flat hammer... that one really made me smile
Old Jan 13, 2009 | 09:41 AM
dblj16380's Avatar
dblj16380
I rented a ball joint press from AutoZone and all it had were flat cups. If it would have had a taper on it I would have probably had very little problems. I'll have to keep that in mind if I have to do them again someday.
Old Jan 13, 2009 | 09:49 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I rented a press, and the cups were either too tall or too short. I had to have my neighbor, who pretty much has his own machine shop, make a cup so I could press the lowers out.
Old Jan 13, 2009 | 02:38 PM
dodgeram07's Avatar
dodgeram07
Originally Posted by dhvaughan
you can borrow most if not all the tools from advance.
+1
if you are going to rent a press get the one from advance.... autozone doesn't have the right cups for 2wd
Last edited by dodgeram07; Jan 13, 2009 at 02:41 PM. Reason: same reason before... + who looks at his
