Stuck Oil Filter
Old Jan 19, 2009 | 03:08 PM
meanwhitemopar's Avatar
meanwhitemopar
i think just get underneath, grab the sucker with a nice size pair of channel locks, and give her a twist, the worst its going to do is just rip the metal off the whole thing in which case you an do like apa228 siad with the holes in the top. and this is caused by the overtightening of the filter on installation, like everyone said, just hand snug, the pressure of the motors oils sytem it will keep it in place and eventually "tighten"...
let us know when it comes off
Old Jan 19, 2009 | 03:19 PM
sungod's Avatar
sungod
The problem with channel locks is that the jaws don't typically extend far enough to get around the filter. I would get these:
or one of these:
Old Jan 19, 2009 | 03:23 PM
aim4squirrels's Avatar
aim4squirrels
Try this:
http://www.northerntool.com/webapp/w...70_47787_47787
Old Jan 19, 2009 | 03:37 PM
Kaldir's Avatar
Kaldir
I know you prolly are, but just so it can be said, make sure you are screwing it the correct way. There are plenty of times where people can mistake the way to turn it because its upside down.
Old Jan 19, 2009 | 07:26 PM
ramario99's Avatar
ramario99
DONE. finally i got it off. i had to rip open the filter and just hit it with a blunt chisel and hammer and screw it off. i tried the channel lock pliers and didnt work ( it did help me break the filter apart.) thanks for all those great tips. ill remember them if for some weird reason this ever happens again, which i think it won't. \m/
Old Jan 19, 2009 | 09:15 PM
aim4squirrels
Glad you didn't have to pull out the torch.
Old Jan 19, 2009 | 10:31 PM
dhvaughan's Avatar
dhvaughan
i've got a pair of pliers like this that made with the curve to fit oil filters. it works really good. i think mine we about $10-12.
http://www.northerntool.com/webapp/w...atchallpartial
Old Mar 29, 2021 | 07:25 PM
Sandra Fales's Avatar
Sandra Fales
Default Oil filter stuck
Originally Posted by ramario99
I was changing my truck's oil today but when i came to get the old filter off, its stuck. I tried to take it off with the tool that looks like a loop with a handle and it crushed the filter. I also tried the screw driver trick and that did not help . now the filter has a big hole in the middle. Some one told me that the gasket got stuck on to the engine, but how can i get it off? i also tried it with a knife and no luck. Any idea how I can get that thing to unscrew. I want to finish this nasty oil change already. by the way the oil filter's brand is FRAM
so did u figure out how to get it off cause I having the same problem I can’t get it off it’s making me so mad
Old Mar 30, 2021 | 09:10 AM
This is a 12 year old thread..........
What are you driving, and what tools do you have available? I have driven a screwdriver thru filters before, and then used that to lever them loose..... But, that only works if you have the room.
Old Apr 1, 2021 | 10:26 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Harbor Freight sells a locking oil filter wrench that makes removing a stuck filter pretty easy: https://www.harborfreight.com/lockin...nch-63696.html
In the past I've driven a screwdriver through the oil filter, but that didn't end well for me.
