46re Overdrive
Old Jan 23, 2009 | 03:16 PM
  #21
crankbait's Avatar
crankbait
I got the same problem with them slow drivers, my truck kicks in and out at 51 mph. But mine doesn't seem to have a proble pulling a good grade in OD on the freeways
Old Jan 23, 2009 | 06:23 PM
  #22
360dodgeram360's Avatar
360dodgeram360
does the tq converter lock up in third? i thought it only locked up in od.
Old Jan 23, 2009 | 11:12 PM
  #23
charlie1935's Avatar
charlie1935
It will if you have the O/D locked out.
Old Jan 25, 2009 | 04:49 PM
  #24
Requiem's Avatar
Requiem
Default OD
In a 96 long bed 4X4 we had the same issue. What we found was that the tranny would "hunt" a little excessively for overdrive as the TP Sensor went bad. A gear change made a big improvement but pricey. We moved the shift points up some with the TV cable and that helped too. But the best mod we did (in my opinion) was the Transgo TFOD Diesel shift kit. On a 5.9 gas truck. (Transgo recommended it specifically for this application.) Huge improvement to shift firmness, and when it went into lock up it hits firm and stays there. Not harsh either. Around $100 from Summit. Piece of cake to put in.
As I understand it too, a flash can set a higher lock up target in the PCM, but it's still just a target - Actual lock up is hydraulic. Beautiful truck by the way.
Old Jan 25, 2009 | 06:30 PM
  #25
05DodgeRamHemi's Avatar
05DodgeRamHemi
I'm not so sure gearing should be an issue. I am running 285 tires with 4.10 gearing; that should probably be right on the money speedometer wise.
I don't think there is a "problem", I just feel like dodges in general seem to make a big deal about overdrive. Maybe it's because they are built up more than other trucks, but when I drive my dad's f-150 or my dad's truck, they shift like a car almost. My truck gets into overdrive around 48-49mph, so it sucks getting behind people doing 45 in a 45 because I don't want to sit there hovering around overdrive, but not actually being in it. Once it's in overdrive and nobody is in my way, it operates very nicely. That's all I mean though.
Old Jan 26, 2009 | 06:00 PM
  #26
lastrights's Avatar
lastrights
how is that new tranny working out for ya ???
Old Mar 22, 2009 | 11:42 PM
  #27
01sportoffroad's Avatar
01sportoffroad
Default Problem with 01 ram tranny
I recently purchased an 01 dodge ram 1500 sport off-road with roughly 105,000 miles on it. The truck has the 5.9 with the 46re automatic and 4.10 gearing. The truck runs like a champ, except i've been noticing that when i am cruising at highway speeds in overdrive it occasionally likes to jump 100rmps or roughly and return to it's normal engine rpms. it tends to do this more when cruise control is activated, and when i hit bumps it occasionally causes the transmission to do this also. I have noticed the problem after the truck has been running for a little while at operating temperature. I was wondering if there is anything i can do to fix this.
Old Mar 22, 2009 | 11:56 PM
  #28
TMS Bill's Avatar
TMS Bill
Does your cruise control disengage when you hit a bump?
Old Mar 23, 2009 | 12:14 AM
  #29
95MaroonMonster's Avatar
95MaroonMonster
my trans can drop into OD at 45 if im not on it, 40 going down a hill if im lucky lol
but at 40 any throttle causes it to jump into 3rd. on hills, unless its one heck of a grade or im really on it, it stays in OD untill about 45.
Old Mar 23, 2009 | 12:22 AM
  #30
05DodgeRamHemi
I had this issue at one time. Whenever I would hit bumps the rpms would rev up briefly. The transmission shop replaced all of the sensors on the transmission, but I believe it was the TPS (Throttle Position Sensor).
