might work?
Old Jan 26, 2009 | 06:07 PM
meanwhitemopar's Avatar
meanwhitemopar
Default might work?
i dought it but i have to ask cause maybe.
i found a 95 trans out of a 2500 deisal, would that fit in my 98 w/318?
they are both automatic so i dont know if that will fit.
Old Jan 26, 2009 | 07:13 PM
jasonw's Avatar
jasonw
Site Moderator
No, it will not bolt up.
The diesel engines use a 47RE (96+) or 47RH (94-95). Your 318 and my 360 use a 46RE. Even if it did bolt up (which, like I said, it won't), not sure what the hydraulic to electronic (RH to RE) would entail.
Old Jan 26, 2009 | 07:15 PM
charlie1935's Avatar
charlie1935
Nope, it won't. You need a 96 or later 46RE tranny. 318 & 360 use them.
meanwhitemopar
alright, i need to find a trans for this truck., rebuild is to expensive
Old Jan 26, 2009 | 07:26 PM
meanwhitemopar
i found a reman on ebay the 46re, for my truck, for like 800. i am going to find out if i could get one
Old Jan 27, 2009 | 12:15 PM
dblj16380's Avatar
dblj16380
You could rebuild it yourself for about 350 including a new torque converter if you have patience and a clean work area.
Old Jan 27, 2009 | 12:20 PM
MonteC's Avatar
MonteC
Im waiting for the new thread... "my 800 dollar ebay tranmission quit working!"
Old Jan 27, 2009 | 12:35 PM
meanwhitemopar
well the 800 dollar trans is a remanufactured one. so it should work just fine. and it has some what of a warrenty
how can i do it for like 350 myself? i mean i have a clean work area, and just about every tool i need, and presses but i have never done that before and it seems like something i would messup,
im not to worried about a total rebuild at that, i just would like to replace the low-reverse band in the trans, if hat ould work, or a total rebuild would be a must.
hey there monte, can you give me a quick little 30 sec rundown on wht all goes into a trans rebuild and if i would be capabable of doing this?
Old Jan 27, 2009 | 03:45 PM
MonteC's Avatar
MonteC
30 second rundown? Building a transmission isnt like an oil change.
Old Jan 27, 2009 | 10:42 PM
meanwhitemopar
well i know that, but like 16380 said i could do a rebuild for about 350 by myself. if this is true nd how much do i need to know about this so be able to do it
