Advice on gear, part upgrades after lift/tires
Old Feb 10, 2009 | 01:29 PM
  #41
gipperkid's Avatar
gipperkid
Can anyone give some insight on "thick" gears and using the stock front carrier?
Old Feb 10, 2009 | 01:40 PM
  #42
dodge15004x45.9's Avatar
dodge15004x45.9
I was thinking a gear change I wanted to do 4.86 up front and a 4.10 in the rear if I can. Can you event do that? My rear now is a 3.55 and my front I think is 4.10. I have a 01 1500 Reg cab 4x4 5.9 auto.
Old Feb 10, 2009 | 02:31 PM
  #43
Zacharynels's Avatar
Zacharynels
Originally Posted by talon6
rims with 4.53 backspacing will cure your rub. thats what i have. i think the stock rims have something like 5.85 backspacing.
i went from 33's to 35's and could notice a immediate difference in braking and acceleration. i will be going to 4.56's some time.
my tire and rim combo weigh like 98lbs.
[img=http://img135.imageshack.us/img135/813/picture002lh5.th.jpg]
Yeah I am hoping to upgrade my rims first, then my gears after. Nice little chunk of change for it all though. =/
Old Feb 10, 2009 | 02:56 PM
  #44
Silver_Dodge's Avatar
Silver_Dodge
Sure, you can do that. But you will never be able to use 4 wheel drive again without leaving some parts on the ground as you roll to a stop. Gears in the front and rear have to be the same.
Old Feb 10, 2009 | 08:44 PM
  #45
helms's Avatar
helms
i think ford used to purposly mis-match gears for some reason, not much, but i think they would go like 0.5:1 differance between the front and rear, wierd
Old Feb 10, 2009 | 11:51 PM
  #46
dodge15004x45.9
Why. So could i run 4.10 and 4.10? what are so choices? So I have to leave my 3.55 alone than?
Old Feb 11, 2009 | 12:51 AM
  #47
helms's Avatar
helms
no, when you change one set of gears you have to change the other, unless you only do the rear and dont engage 4wd until you change the front to match
Old Feb 11, 2009 | 12:56 AM
  #48
helms's Avatar
helms
sorry i just read the earlier posts.
If your gears are mismatched right now, they are wrong, someone has changed them. they are supposed to be the same.
if the front is a higher gear (numerically lower) than the rear, when 4wd is engaged, the front tires will turn faster than the rear at any given RPM resulting in either the front tires spinning while the rear catches up, or the front grabbing and skidding the rear tires because they cant keep up, depending on which end has more traction.
Old Feb 11, 2009 | 01:16 AM
  #49
Silver_Dodge
They can actually be off by just a little, and in fact are usually designed that way on purpose to compensate for things like longer drive shaft in the rear, turning in the front, chain play in the transfer case, etc. In fact, when I had 4.10's from Yukon, the technical spec on the gears was that the front was a 4.09, and the rear was a 4.10. This is not enough to make a difference (Randy's told me they can't be more then .02 different), but I thought it was interesting.
But ya, if you have a 3.55 in one, and a 4.10 in the other, then you now have a 2wd truck because you'll grenade it if you try to drive in 4x4. Are you sure that's what you got?
Old Feb 11, 2009 | 09:20 AM
  #50
dodge15004x45.9
so what do I have than? I know I have a 3.55 rear.
