performance upgrades
Old Feb 10, 2009 | 07:02 PM
wjxavier's Avatar
wjxavier
Default performance upgrades
any suggestions as to performance upgrades i can do to my '95 1500 5.9L. i already have a CAI installed, thats about all im going to do as far as intake for now, unless theres any other suggestions. im thinking dual exhaust and maybe new headers(if i can get the bolt i broke off inside the engine block out lol) any other upgrades that you can think of? any input appreciated! thanks!
Old Feb 10, 2009 | 07:13 PM
98cherryram's Avatar
98cherryram
New exhaust, headers, gut the cat, cut the cat out, or get a high flow cat, new tb, probably holley or fastman, do a tuneup, all new sparkplugs, 8.5 mm wire(stock is 7mm), new cap and rotor, Do a fuel system cleanout, I felt like I was driving a new truck when I did that, 1.7 harland sharp roller rockers, 4.10 gears depending on what tires you have, but even so, still, 4.10 gears, paint the engine components(+5 hp as long as its not ford blue) electric fan, 408 stroker, procharger supercharger, but that stuff might be leaving your idea of performance mods, your looking more bolt on
Old Feb 10, 2009 | 07:21 PM
madmax0r's Avatar
madmax0r
Just do a quick search, there are like 100 threads on this, check out the DIY sticky thread too
Old Feb 10, 2009 | 07:24 PM
wjxavier's Avatar
wjxavier
yea im looking more bolt on right now. as far as supercharger, that will be much later down the road when i get the money to do so. i plan on doing headers, dual exhaust(possible straight pipe?) i was looking into radiator fans like you said, so thats a possibility. probably a new tb as well...i dont know if i'll do anything with the gears right yet, they'll probably stay where they're at for now. and as far as tune-up(spark plugs, wires, cap, rotor) that'll probably be done as well...i appreciate the info! thanks! any other "bolt-ons" i can do? appreciate all the help guys.
Old Feb 10, 2009 | 07:29 PM
CaptCameltoe's Avatar
CaptCameltoe
Heres what I have found to be the most beneficial on a magnum powered truck and in order of importance. Of course first step is to make sure your baseline package is runnin right with a good tune up and systems check of all your sensors, replace any that need it.
1.Exhaust, headers, no cat and good free flowin muffler
2.CAI
3.Mopar perf PCM or after market tuner
4.3pc Underdrive pulley set
5.Elec fan setup
6.trans cooler
7.shift kit
8.steeper gears and a posi
9.You can put roler rockers here, but I'm not a fan of them
10.cam, springs, but that all depends what you want to do and this can cause a chain reaction of parts needed to make it all work right together.
11.Throttle body, but never felt the need to do that on my trucks. Just don't see the need on a mild bolt on truck or think there's much gain on this part, but others might disagree.
Old Feb 10, 2009 | 07:34 PM
wjxavier's Avatar
wjxavier
thank you very much everyone, i appreciate it!
Old Feb 10, 2009 | 07:36 PM
CaptCameltoe
Talking
1-8 should have you rollin pennies for gas money, but happy
Old Feb 10, 2009 | 07:43 PM
wjxavier's Avatar
wjxavier
thanks, any other bolt on ideas?
Old Feb 10, 2009 | 08:16 PM
dodgeram07's Avatar
dodgeram07
if you are getting header you need them with a egr port only 94-95 need a pot on the header
when looking for a tuner you will not find much it being a obd1 this and mp pcm is about all http://www.hypertech.com/Products/Po...uning%20Module
the hypertech maybe just as good as the cran pos mod i don't know,,,,,,,,,,
is this link working?? it's not for me.. it was or is a good little site??
http://www.v8performance.com/tipsandtricks.htm#cabpop
Old Feb 10, 2009 | 08:57 PM
lastrights's Avatar
lastrights
get a highflow cat,rollor rockers,headers,b&G FLASH for your truck, ngk plugs,msd wires,cherrybomb extreme,
