Valve cover gaskets-- reusable?
Old Feb 18, 2009 | 05:47 PM
dhvaughan's Avatar
dhvaughan
i used the expensive felpro rubber/metal gasket with no sealer. no leaks. just clean both surfaces.
Old Feb 18, 2009 | 06:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you use the new bolts that came with the kit , or your old ones ? Just curios.
Old Feb 18, 2009 | 06:49 PM
Silver_Dodge's Avatar
Silver_Dodge
Originally Posted by highlander73
I used the Fel-Pro blue gasket with no silicone, which is how Steve recommended it be done. No leaks yet, but Silver likely doesn't have any either. A new gasket with proper torque (and Locktite too, right?) will work well with the new aluminum pan.
No leaks here.
Old Feb 18, 2009 | 06:51 PM
aim4squirrels's Avatar
aim4squirrels
I'm still not sure why he needs to pull the valve covers to change the plenum gasket?
Old Feb 18, 2009 | 07:07 PM
ophidia's Avatar
ophidia
I have the metal/rubber felpro gasket kit as well. I'm just doing the valve covers at the same time since they're oozing a little. I figured they're not going to be any more accessible any time in the near future.
So it seems I have a decision to make-- ultra copper vs. nothing. I bought the ultra copper so I'll just have it on hand and decide if it looks like it needs it or not when I have it apart.
Thanks for the help guys.
Old Feb 18, 2009 | 08:26 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Originally Posted by ophidia
Is the Ultra Copper different than the other high temp RTV silicones? I have the red ultra stuff. If not it's < 5 bucks for a tube, I guess.
Yes the ultra copeer is different. I don't really think it's silicone based but I might be wrong. I just know that it worked real good for my plenum replacement.
Old Feb 18, 2009 | 10:22 PM
ophidia's Avatar
ophidia
I cracked it open, and it definitely smells different-- more of an earthy scent rather than the vinegary smell of regular RTV. It seems to almost be a bit gritty too.
Old Feb 19, 2009 | 12:06 AM
Silver_Dodge
Keep smelling it, and you be feelin' fine in no time.
Old Feb 19, 2009 | 07:27 AM
dhvaughan's Avatar
dhvaughan
how's it taste ? probably sort of sticky, like peanut butter.
Old Feb 19, 2009 | 08:36 AM
turkeyhunter1962
Unhappy
Just make sure that it didn't come from that bankrupt peanut butter plant that shipped all of that salmonella contaminated stuff. The salmonella would get ya sicker than hell and the sealer would close you off.
That would be ugly:
