sounds like it wants to shut off
Old Feb 24, 2009 | 10:02 PM
notanexit7's Avatar
notanexit7
Originally Posted by madmax0r
hey, make sure your throttle positioning sensor is plugged in well, and working, It will make the engine chug like you say if its going out.. replacing this fixed all sorts of quirky problems with my truck Including the cruise control
Alright. i'm not a mechanic by any means so don't laugh at me for askin but is the throttle sensor easy to get to and replace. I'm gonna look at that and the iac thing that zman was talkin about too if yall think it will help.
Old Feb 24, 2009 | 10:10 PM
madmax0r's Avatar
madmax0r
yessir it is.
if your standing on your bumper looking down at your throttle body, its the sensor on the right side directly inline with the butterfly valves. the IAC is the one directly on the back side of the Throttle body
Old Feb 24, 2009 | 10:24 PM
notanexit7's Avatar
notanexit7
yessir it is.
ok thanks a lot man i'll check those out tomorrow morning and see if that helps any.
Old Feb 24, 2009 | 10:27 PM
madmax0r's Avatar
madmax0r
for sure, the plus side of those two, is they are pretty cheap (30-40 dollars) so its not the end of the world just to try it
Old Feb 25, 2009 | 03:04 PM
PurplDodge's Avatar
PurplDodge
HAHA!!! PURPLE!!!!!!!
Hemi Orange grille anyone?
Old Feb 26, 2009 | 11:27 PM
notanexit7's Avatar
notanexit7
hahaha i'll keep mine stock. i like the stock look for our trucks. anyhoos, i went to nappa auto parts and explained this whole problem with the guy at the front and he said the sensor's could be the problem and it could also be the fuel filter stuff in the tank. So i drove down to the dodge dealership and explained to them the problem and they said that they eliminated the fuel filter in our trucks and most of their cars when they redesigned our trucks in 94 and that the filter screen in the tank rarely ever goes bad, the same for the pressure canister thing on top of the tank. So i'm back at the conclusion to go ahead and replace the tps and the iac which are 56 and 69 bucks respectively. should i replace one first and see if it helps or do both at the same time?
Old Feb 27, 2009 | 04:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you try cleaning first? Even if you replace one or both, you'll want to clean the TB where they install to. I'd go with the IAC first if cleaning doesn't help.
