a smaller tire turns faster.. just say and 30in tire and (baby dayton) 15in tire the dayton will have to go twice as far as the 30in....... so if you were doing 40 it would say 80, and math wise it would double the mpg
Exactly. That's is the same outcome I stated, except you went with the smaller tire analogy and I went with the larger. I bet he understands now though .
When I do it, I will be leaving the 3:55's in, so I should be good to go. When it's done, I'll also be doing the sand trick in the intake to do some polishing for a week or so. So I'm hoping for close to 90 mpg.
team work
zman don't forget the hair dyer turbo, jason is right you should get the 3.21... but your so cheap that you would keep the stock 3.55
Lol, who could forget the good ole' sand polishing trick. LMAO... that thread was priceless
I was going to go with the 3:21's , but times are tough. What suck's is, I should have read this thread before I wasted the $39.99 at the Holiday Inn a couple days ago. That would have paid for the balancing of the tires anyway.
