Cut off my muffler
Old Mar 4, 2009 | 01:44 PM
  #31
lastrights's Avatar
lastrights
i have the extreame its awesome, i want to cut off my muffer too lol
Old Mar 4, 2009 | 02:04 PM
  #32
vmann's Avatar
vmann
how does the cherry bomb sound? im thinking i want to get one because they are cheap
Old Mar 4, 2009 | 02:42 PM
  #33
dodge15004x45.9's Avatar
dodge15004x45.9
There not bad mine was 150.00 but I got it for 90 and change.
Old Mar 4, 2009 | 03:37 PM
  #34
hometheaterman's Avatar
hometheaterman
Originally Posted by mcss8541
When I bought my truck it didn't have a muffler on it just a straight 2.5" pipe from the bach of the cat to the end where it split off into 2 tail pipes. I decided to increase the straight pipe to 3" recently and my truck isn't running as good. I'm going to install a muffler on it either the thrush or the flowmaster. I have read many a threads that states if you are running a stock motor that if it doesn't have a certain amount of back pressure it will start to burn the edges of the valves because the exhaust gas is leaving too fast. Now the question I have is the guy who does my exhaust work is real good and he stated he had a muffler in stock that's the exact same as the flowmaster 40 series but it's by a different manufacturer. He said that Flowmaster's patent had expired and the gov't had not renewed it so now a lot of muffler manufacturers are turning out the same design but only changing the color a little to be within the guidelines. What do you think? Also the Dynomax Thrush muffler from Summit does not come in a single center inlet and outlet....at least not what I saw, does anyone know if they do and is so could you post the link? Thanks.
I think it doesn't run as good because you have 3" dual pipes. That's way too big. Go with 3" for a single pipe or 2.25" for duals. Some go 2.5" and that seems to be fine too but no bigger if it's duals.
Old Mar 4, 2009 | 03:54 PM
  #35
lastrights's Avatar
lastrights
this is cherrybomb extreme w/highflow cat http://www.youtube.com/watch?v=ExWcbsh-oxA
this is just the cherrybomb extreme with stock cat http://www.youtube.com/watch?v=7kMkZ...eature=related
this is another 2nd gen with the extreme on http://www.youtube.com/watch?v=lTcDm3EetHA
in my opinion its awesome, my cousin had the flowmaster 40 on and mine was always louder and more aggressive, it always made him mad mine was always louder so he cut his muffler off and his ended up being louder.lol
Old Mar 4, 2009 | 10:09 PM
  #36
vmann's Avatar
vmann
where did you get yours?? ive seen them on summit for like 30 bucks
