Last edit by: IB Advertising
Browse all: Electrical System
- Dodge Ram 2nd Gen How to Reset the PCM
Step by step instructions for the do-it-yourself repairs.
How do you reset the pcm
#31
PC there's a quicker and cheaper fix. Check this out go to the autoparts store and buy a spark plug non fouler they are 18mm which is the exact thread of your O2's. Put the lower end in a vise and snug it down. Take a hacksaw or a cutting tool and cut off the top octagon ( stop sign looking, like you could put a socket on it )portion off and toss the rest. Take drill and drill a hole in the location you are installing the O2 ( measure the correct location) weld that on and you have an O2 bung. I just did mine last week after replacing the straight pipe than ran between the cat and the tail pipes. Total cost $7 which included the welding. I do have a question what size is the cat AIM was referring to? Name of it?
#32
I've heard of the fix before, it was mentioned as well in my thread I posted a few days ago when I threw a code. Honestly I don't know if it will pass visual inspection for my state which is why im very hesitant on doing it. Aim was talking about the 99xxx series cat's btw.
#33
Want to pay for my new one? There is a difference, but I just dropped $140 total to put a highflow into my truck six months ago. That cat is not working so now I have to replace it with a "bigger" cat to keep with emission standards. I kinda disapointed with the forum a bit since so many people recommend them, but then at the same time they get a check engine light for it down the line. I didn't find out till the other day just how many there were that had this problem. Aim has found a bigger cat, but its still a thorn in my side knowing that I just dropped $140. Well the new cat costs around $130 local + I need pipe to run from the cat to the muffler since the stock pipe is very fragile. Add in the o2 bung, install, etc.. Looking at $200 minimum I fear. I should have just left the perfectly good stock cat still in the truck. Lesson Learned!
#34
Thank you! This worked for me when i changed the battery
#35
The following users liked this post:
Adam Sorensen (12-31-2019)
#36
#37
#38
#40
I suppose you could start by cleaning the TB and IAC. Remove the negative battery cable before the procedure.
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
And while your in there route the wires according to this TSB.
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
