Plenum Gasket
Old Mar 1, 2005 | 04:03 AM
cnewt15's Avatar
cnewt15
Default Plenum Gasket
How do I tell if i need a new plenum gasket? I look down thru the throttle body, and the bottom of the pan looks wet. Is this unspent fuel? Oil? Or should it look dry as a bone down there?
Old Mar 1, 2005 | 01:50 PM
steve05ram360's Avatar
steve05ram360
Default RE: Plenum Gasket
you will see oil on the bottom of the plenum, look down the throttle body to see it. there is a TSB on it as well with a test that DC gives but I hear it's not that conclusive... Plenum Leak TSB
Old Mar 1, 2005 | 02:36 PM
Snafu's Avatar
Snafu
Oh, that looks like a bitch to change....
Old Mar 1, 2005 | 02:51 PM
steve05ram360
It's easy... just takes time and patients...
Old Mar 1, 2005 | 07:50 PM
cnewt15's Avatar
cnewt15
I ran the test and i got 15 lbs at the breather. with the pcv port on the intkate blocked off.
Old Mar 1, 2005 | 08:53 PM
cnewt15's Avatar
cnewt15
also, does this effect gas mileage, and power?
Old Mar 1, 2005 | 09:21 PM
steve05ram360
yes, it affects both milage and power, you have a vacuum leak... both will suffer.
Old Mar 1, 2005 | 10:30 PM
cnewt15's Avatar
cnewt15
Ok, next question, how hard is the intake to get off, i am a mediocre mechanic, but i have never pulled one off a 318 truck, does the dist have to come out, or just the cap?
