Old Aug 5, 2015, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
ABS light & brake light on!!! Already check the obvious.
Old Apr 7, 2009 | 09:47 PM
  #41
olyelr's Avatar
olyelr
Originally Posted by J415
Yup, sorry to be the bearer of bad news. I got the code from a book that I have. I have a code reader that came with a book for it so you can reference it. But it's definitely a tranny code. Don't know if it's the same thing but my tranny guy replaced my governor solenoid about 2 years ago 'cause it was on it's way out for 80 bucks. so that was a relatively cheap fix.
Hmmm, well thanks for the info. I better get that checked out soon. I know how these trannys are, and one thing leads to another leads to another... It will be much cheaper to get it fixed sooner. Thanks!
Old Apr 10, 2009 | 12:44 AM
  #42
ShagginWaggin's Avatar
ShagginWaggin
Sorry to hear that. As soon as the lights went on I changed the ABS speed sensor (the one on top of the rear diff) and drove it home (100 mile drive) with both light on all the way home. Then as soon as I got home I rest the PCM AGAIN and reconnected the brake light switch and the light hasn't came on since. I still, however, get those light "step down" type of feeling every now and then. The one's that feel like farts. Out of curiosity I checked out the Reservoir and the grommets in between the Master Cylinder and the Reservoir were damp. So I took a small inspection mirror and I saw a leak that was developing. It was like a tear drop that was about to form, but it wasn't big enough to trickle down. I'll be changing the MC pretty soon. The farting, I think, is "blow by" at the Master Cylinder, hence, the farting of the break pedal and the leak. I hope you have the same problem as mine so that this will work for you. I'll keep you posted.
I got those same grommet leaks on my 99 1500 van. I'm hoping just to replace the grommets with new ones i bought. Can I do this or will I need to replace the whole cylinder? Thanks
Old Apr 10, 2009 | 01:00 AM
  #43
J415's Avatar
J415
well, obviously you can physically do it but I'm just gonna replace the whole MC since it has 150K miles on it. Those grommets are a REAL son of a gun to pry off. Then you have to worry about "did I crack or break anything?" I'll skip on THAT headache. Your call though. Either way, good luck
Old Nov 19, 2022 | 06:53 PM
  #44
Bob Forsman's Avatar
Bob Forsman
Default ABS and Brake light on/2001 Ram 2500 V10 4WD 4 W ABS
This problem started when I was parked on pretty good grade with a toy trailer attached, so I set the parking/emergency brake on for help. Went and checked around the truck got back in Started truck and release parking/emergency brake, the brake light stays on and now I have an ABS light to. The brakes work fine, the speedometer works fine, no other issues.I am not sure the ABS system is working. (That was the first time I ever used the parking/emergency brake)
I have checked the fuses, all of them all good, replaced the ABS sensor in the rear differential, I read one forum that changing the ignition switch fixed the problem. Have not done that yet. I read take the negative terminal off with the Key in the on position wait 30 seconds then depress brake pedal for 30 seconds to clear the memory, but that did nothing, now I just read another one it said to take off the Positive terminal and then just press the brake and hold for 30 seconds, I do not think that will make a difference but will try that now, did not do anything.
Will look into and ignition switch.
Old Nov 19, 2022 | 08:02 PM
  #45
Check the e-brake switch on the pedal assembly, it may be the pedal is not returning completely, or, the switch is just bad. That will annoy the ABS system. If that ain't it, take it to somewhere that will read abs codes for ya.
Old Nov 20, 2022 | 01:20 PM
  #46
Bob Forsman
initially thought that was the problem, could not see a switch, will look again. Thanks
Old Nov 20, 2022 | 07:13 PM
  #47
I think it is hidden... Could try just pulling the release, and trying to pull up on the pedal, see if that makes any difference.
