Will 15" wheels work on a '98?
Old Mar 18, 2009 | 01:31 AM
JohnnyRebs360's Avatar
JohnnyRebs360
Question Will 15" wheels work on a '98?
I was wondering if there is any of y'all running a 15 inch wheel? And if so, I would like to have the dimesions. You can't find a LT33x12.50R16. That is why.
Old Mar 18, 2009 | 11:11 AM
Ram2K1's Avatar
Ram2K1
I think you can run 15's on a '98, but do a search on here to find out for sure.
For 16's you'd have to run something like a 295/75R16 ~ 33.4x11.6, or 305/70R16 ~ 32.8x12.
Old Mar 18, 2009 | 11:46 AM
olyelr's Avatar
olyelr
I have not heard of anyone having problems with 15" steel wheel clearing the calipers, but some people have problems with the aluminum wheels... it just depends on the wheel. My brother had 15x10" aluminum wheels on his 01 truck (dual piston calipers) with no clearance problems.
And as far as tires go, like Ram2k1 stated, just get a 305/70/16. Its basically the exact same size as a 33x12.5, just has different numbers on the sidewall
Old Mar 18, 2009 | 09:17 PM
LegendKiller89's Avatar
LegendKiller89
I run a 15'' rim on my 96 no problems at all! And I have 33x12.5 tires as well.
Old Mar 19, 2009 | 12:50 AM
JohnnyRebs360
I need to know the offset and back spacing
I thnk I just want a 33" tire without all the width.
I wish they made a 265/95R16 or 265/100R16 tire
Old Mar 19, 2009 | 02:12 AM
dakotas ram's Avatar
dakotas ram
the ones in my sig are 15s
Old Mar 19, 2009 | 07:09 AM
olyelr's Avatar
olyelr
Well, what is wrong with the 285/75/16? Those measure 32.8x11.2 or so, is that too wide? Its not even an inch wider than the 265's.
Your other choice would be to buy 15" rims and get a 33x10.5x15 or a 33x9.5x15, which I know BFG sells both of those sizes and a few others may as well.
But, if you already have a 16" rim I would just get the 285's (unless that is wider than your likings).
Old Mar 19, 2009 | 10:27 AM
Ram2K1's Avatar
Ram2K1
I just noticed in your sig, you already have 285/75's on there...you won't get much closer to 33" than 32.8" with a 16" wheel.
Old Mar 20, 2009 | 01:02 AM
JohnnyRebs360
You're right I do have 285 on my truck. I like them, but I wanted to see if there were an option to get a 15 inch wheel. So it could be easier to get the standard tire size vs. getting the metric. Plus I will problaly get new 285/75r16 soon. I thought about getting news wheels (polished aluminum) in either a 15" or a 17". But since the economy is upside down I will stick to the 16".
Old Mar 20, 2009 | 11:00 AM
Ram2K1's Avatar
Ram2K1
No problem...I think these trucks look great with 285's with or without a leveling kit...I have 265's, but I want 285's. Maybe after I get a aftermarket tranny
