Bad Fuel Guage
Old Mar 25, 2009 | 05:49 PM
rafter40's Avatar
rafter40
Default Bad Fuel Guage
Hi. I have a 2000 ram 1500 sport 5.9 and i drove about 120 miles after filling up my tank and the gauge stayed at about 7/8 of a tank. i did put injector cleaner in after filling the truck with $36 when the guage was at a half tank. Is there anything i can do to fix the guage? i did clean off the cluster of guages and slightly moved some of them... could this have caused a problem?
Old Mar 25, 2009 | 06:01 PM
TMS Bill's Avatar
TMS Bill
It's not broken. After a fill up, I go about 70-75 miles before it moves off the F mark ... then about 30 or so miles per 1/8th. It's done that since the day it was new.
Old Mar 25, 2009 | 06:03 PM
Ram2K1's Avatar
Ram2K1
It could have moved when you cleaned it, or it could just be the float sticking.
Old Mar 25, 2009 | 06:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If it didn't do it until you cleaned the cluster of gauges, you may have bent the spring for the needle slightly while you were doing this.
Old Mar 26, 2009 | 11:07 AM
rafter40's Avatar
rafter40
thanks guys... every thing you guys said makes sense to me. it could be n e of the three. If the float is stuck is there a way to free it? how many gallons is the fuel tank and about how many miles do u guys get per tank?
is the spring for the needle difficult to fix?
Old Mar 26, 2009 | 11:27 AM
TMS Bill's Avatar
TMS Bill
Did I misread your post? Does the gauge top out at 7/8 and then not move for 120 miles or does it get to F and then after 120 miles, you're only down to 7/8?
I've got a 26 gallon tank and fill it up when the light dings on (about 1/8 tank). The most I've ever gotten out of it is ~300 miles. I routinely got 275-280 but this last tank looks like it will only take me 230-240. I've had to do a lot of driving in downtown Ft. Worth and recently swapped in my MP PCM. Feels great on the butt dyno but not so sweet on the wallet.
Old Mar 26, 2009 | 11:29 AM
Ram2K1's Avatar
Ram2K1
My fuel tank is 26 gal, and I think that is pretty standard. Sometimes running that Chevron Techron additive stuff for a while can help faulty floats and/or sending units, but it's hit or miss. I don't know what everyone else gets, but I am lucky if get any more than about 275 miles out of a tank on straight city driving. I mean, there are usually about 4 gal left when I fill up, so I know I could get more, but I don't like to suck that gas out of the bottom unless I have to...not healthy for the fuel pump/filter. I guess if I ran it bone dry, I would get about 300-315 miles out of a tank.
Old Mar 26, 2009 | 01:44 PM
rafter40's Avatar
rafter40
ok cool. i was just trying to get a ball part idea of how far i should run it before it needs refilling. I just got the truck 2 weeks ago and filled it up for the first time and it didnt seem rite, but i guess ill just drive it and see what happens.
TMS Bill. I think you read it right the first time. When i filled it... the guage went to full and has only dropped minimally since then... but maybe that is normal.
Old Mar 26, 2009 | 03:20 PM
Ram2K1's Avatar
Ram2K1
Mine does that, too. That first 1/8 or so of the tank seems to last forever, but then it kicks in and sucks it down quick.
