V10 Oil Pump Replacement
Old Mar 3, 2010 | 06:13 PM
VEETEN's Avatar
VEETEN
Originally Posted by MJCola
So are these 5 torx screws located outside or inside
Inside
Old May 5, 2010 | 05:50 PM
megaman52's Avatar
megaman52
Default oil pump
Maybee I didn't readfar enough but can anyone tell me where i can find an oil pump for a 1999 ram v-10????????????????????
Old May 5, 2010 | 05:52 PM
megaman52's Avatar
megaman52
Can anyone help me find an oil pump for 1999 dodge ram 2500 v-10?????????????//
Old May 5, 2010 | 06:49 PM
VEETEN's Avatar
VEETEN
Try the dealer.
or
http://dodgeparts.mopar.com/dodge/oem-dodge-parts.html
the rotor kit is about $80
Old Jun 19, 2010 | 11:03 AM
Spivey's Avatar
Spivey
Default timing cover
I'm looking for a timing cover for a 1996 dodge ram v10 8.0 can anyone help and let me know i can fine one at. I have install a new long block and can not keep oil pressure. i can prime it and get 25psi but when I cut it off and start it back up I lose oil pressure.
Old Jun 19, 2010 | 05:47 PM
VEETEN's Avatar
VEETEN
Most parts for V-10s (engine parts) are gonna be dealer only items.
there are few places that carry mods for them due to the fact they are pretty rare.
And junk yards almost never have v10's on the lot.
Welcome to DF
Old Jun 21, 2010 | 07:26 PM
Spivey's Avatar
Spivey
I'm finding that out. and the timing cover. the dealer does not make no more and can not fine one in the junk yard.
Old Jun 21, 2010 | 07:38 PM
Check with your local junkyards, most of them will have a parts locater service, and should be able to find one for ya.
Old Oct 12, 2010 | 03:09 PM
ROCKY1's Avatar
ROCKY1
Hello:
I also have a 95 v10 and the oil pressure is about 15ib. @ idle and about 40 ib. when moving. I would have never have figured this out if not for this forum. What is it going to take to remove the harmonic balancer and timing chain?
Rocky1
Old Oct 13, 2010 | 09:13 AM
geggle's Avatar
geggle
you need a special balancer wrench for the dodge. Those bolt on universal contraptions won't work. Napa has the right one. Not expensive
