V10 Oil Pump Replacement
Old Nov 7, 2012 | 11:40 AM
  #21
Rip_jeff's Avatar
Rip_jeff
Where was the pump located at?
Old Nov 7, 2012 | 08:15 PM
  #22
VEETEN's Avatar
VEETEN
behind the timing chain cover.
Old May 21, 2014 | 01:29 PM
  #23
Lelaprovenzano's Avatar
Lelaprovenzano
I'm trying to figure out if i need to replace my oil pump or not, my oil pressure gauge keeps bottoming out about every 8 seconds if i'm driving..
Old May 21, 2014 | 03:05 PM
  #24
Put a mechanical gauge on it, and see what pressure does at idle. (also, make sure oil level is correct......) If it really is low, stop driving it, and replace the pump. (a fun exercise.....) if the mechanical gauge says things are hunky-dory, replace the sending unit.
Welcome to DF!
Old May 21, 2014 | 04:14 PM
  #25
Lelaprovenzano
Ive replaced the sending unit three times and know there is a really bad knocking noise...
and i cant find an oil pump anywhere, the dealership by me only sells the oil pump cover
Old May 21, 2014 | 05:15 PM
  #26
Jimythefan's Avatar
Jimythefan
The oil pump is part of the timing chain cover. It sits right where the crank comes through. Check the pic in the beginning of the thread and you'll see where it is.
I posted a pic from the parts manual in this thread showing the oil pump rotors. They fit around the crank in the timing cover.
https://dodgeforum.com/forum/2nd-gen...-2500-v10.html
Old May 21, 2014 | 05:35 PM
  #27
If you have a knocking, low oil pressure may just be the beginning of your problems, and replacing the oil pump may not fix it. If it is a bottom end knock, you need to drop the pan, and see what's up.
Old Dec 18, 2018 | 04:12 PM
  #28
Lb13's Avatar
Lb13
Default Oil pump replacement
Recently replaced the timing cover and oil pump on my v10. Had to find another motor with a good cover and pump in it. Does anyone know if and how I need to prime the pump before trying to start the engine?
Old Dec 19, 2018 | 10:02 AM
  #29
Pack it with lithium grease when you install it. I believe that's the best you can do.
Old Feb 2, 2019 | 03:38 AM
  #30
Thomas VBC's Avatar
Thomas VBC
I have a similar proble to the original post from ten years ago lol. Picked up a 2001 dodge ram 2500 v10. I had it parked for a while doing rockers cab corners etc. started it up and oil pressure was at zero check gauges on, then it kicked up to normal after about 30 seconds During this time there’s also a slight knock/lifters tick. After it warms up there’s no noises and my pressure is right around 40. I checked my oil dip stick and I have safe line oil wasn’t the best but it was full. Looked around and the oil pressure sending unit on the oil filter was broken off And if I pushed it in I’d get different oil pressure readings. So I got a new sending unit I’m hoping that and an oil change will fix the cold start knock I was hearing.. should I check my oil pump as well? screws backing out seems to be common here. I can’t find much info on it, how to rebuild it or what it really looks like.
i did also order a new oil pan mine is starting to seap oil so I will have to look around down there as well. I’m not sure what I’m really looking for besides crud in the draw tube(id like to upgrade to the bigger pump/tube screen if I could find one). I have had it parked since I noticed this was going on so I’m hoping whatever damage is minimal. I’m not really a mechanic I’m more of a body guy. Thanks in advance for any feedback
