Modded TB and round air hat installed (pics)
Old Mar 29, 2009 | 01:45 PM
CSXfan's Avatar
CSXfan
Default Modded TB and round air hat installed (pics)
Hi all,
I slapped my modded TB and a Mopar Performance air hat on my truck yesterday. Didn't go as smoothly as I would have hoped, but it's sorted out for the most part now.
(rant warning) I ran into a problem with the modded throttle body. I took a TB off a '95 318 to use on my '99 360. For some stupid, unknown, useless reason, Holley subtracted 1mm from the diameter of the butterfly shaft rings on the TB somewhere between '95 and '99, so my whole plan of switching out the butterfly shaft went up in smoke. So I was forced to try and make the cable connections for a '95 work on my '99. Well, it didn't work very good and I ended up breaking a piece off of the TV cable. So now, I just have a chunk of wire holding the TV cable on. A replacement TV cable costs $47 from the dealer....$@#*!
Anyway, I ran the truck for a day with the modded TB and the round air hat and it was a huge improvement over the stock setup. Throttle response is a lot better, but the most noticeable difference is how much less petal it takes to keep the truck cruising at 70mph. It feels like the truck is barely working to maintain speed. For the moment I'm running with the round air hat and the stock TB until I can figure out a way to make the modded one work. With the stock TB the whistling/whooshing noise is a LOT worse (I actually had someone ask me if I had a supercharger under the hood), but that's really the only difference I noticed between the stock and modded TB.
A pic of the stock TB and the modded one next to each other...
The modded TB (I just milled the top flat)
The Mopar Performance air hat
Old Mar 29, 2009 | 02:11 PM
Cereal Killer's Avatar
Cereal Killer
Looks sweet.
Old Mar 29, 2009 | 02:46 PM
pavement_hater's Avatar
pavement_hater
That sucks. Search junk yards for a TV cable. I broke the end off mine few weeks and found it at my favorite local yard. I paid $2 for it. Now you know why its my favorite junk yard.
Old Mar 29, 2009 | 05:30 PM
lastrights's Avatar
lastrights
when the last time you have done a tune up ??? maybe a clogged cat ??
Old Mar 29, 2009 | 10:04 PM
J415's Avatar
J415
that came out REAL clean. Did you have it machined? If you have no luck getting a TV cable, let me know I can get one for you.
Old Mar 30, 2009 | 07:59 PM
CSXfan's Avatar
CSXfan
I used a reciprocating saw to knock off most of it and then a milling machine to take off about 2mm all the way across it. Considering it was my first time on a milling machine, I think it turned out pretty good. But you can see where I messed up a little on the edges by the locating blocks. Oh well. I might take you up on that offer if there isn't anything at the local boneyards. It's gonna be a while before I can even look for one. The wire I'm using right now works surprisingly well and it's a whole lot easier to adjust than the stock adjuster!
Old Mar 30, 2009 | 09:07 PM
TimSully88's Avatar
TimSully88
What are the benefits to this TB mod? I see that a lot of people have been going down that road lately.
Old Mar 30, 2009 | 09:51 PM
Cereal Killer
Throttle response.
