Fastman Throttle Body
Old Apr 1, 2009 | 05:23 PM
  #61
BigRedRam95's Avatar
BigRedRam95
Is this all I need to do a install
http://hughesengines.clients.nharmon...d&partid=23360
http://hughesengines.clients.nharmon...d&partid=23039
http://hughesengines.clients.nharmon...d&partid=22220
Old Apr 1, 2009 | 05:42 PM
  #62
jasonw's Avatar
jasonw
Site Moderator
That link does not work for us, as the cart contents are saved as temporary files on your computer, scorpion.
EDIT: Sure, now you edited it after I said it didn't work. Trying to make me sound like a fool, I see.
This is what you need if you order from Hughes engines:
-HUG 7714 - The new plenum plate with new bolts.
http://hughesengines.clients.nharmon...p?partid=22220
-HUG 3205B - Another set of (optional, but pretty necessary) gaskets and bolts.
http://hughesengines.clients.nharmon...b&partid=23039
Instead of 3205B you can also get the bolts and a good branded gasket from a local auto parts store, such as O'Reillys. I ordered 7714 and got a Felpro gasket set locally.
Optional stuff (to get from Hughes or elsewhere), but recommended:
-New upstream (pre-cat) oxygen sensor
-New thermostat & thermostat gasket
I am replacing the sensor myself today. I had them replace the thermostat while they were in there, as I still had the original untouched factory unit (preventative maintenance).
Old Apr 1, 2009 | 05:51 PM
  #63
zman17's Avatar
zman17
Retired Moderator - RIP
45 minutes? an hour ? You guys make it sound like getting the nut off your front hub.( Or getting the factory air intake box off) LMAO! It takes almost that long just to clean everything properly. And if a 12 pack is involved not only will it take a lot longer, but the chances of something getting F'd up are greater.
Old Apr 1, 2009 | 06:05 PM
  #64
BigRedRam95
Old Apr 1, 2009 | 06:07 PM
  #65
Mowhawk's Avatar
Mowhawk
My engine bay is pretty clean to begin with, so there wasnt much clean up. Was just careful when i took of the manafold.
Old Apr 1, 2009 | 07:55 PM
  #66
dodge15004x45.9's Avatar
dodge15004x45.9
Mine is clean to lol.
Old Apr 1, 2009 | 08:47 PM
  #67
CSXfan's Avatar
CSXfan
Originally Posted by VWandDodge
^^ Or, you can do like I did and just send him your TB if your truck isn't your primary vehicle. Turnaround was 5 days for me, and that thing is a work of art.
Did that cost you the same amount as buying one from fastman?
Old Apr 1, 2009 | 10:19 PM
  #68
dodgeram07's Avatar
dodgeram07
Originally Posted by scorpion122192@hotmail.com
I did a search and found out that I was a softwere update and I do have that but now how do I get rid of it
what??? you have obd1 i truely think the death flash didn't happen till 1998(the true OBDll), i maybe be wrong but i feel about 99% correct
can you link the info you found??? not trying to be a butt just learning
Old Apr 2, 2009 | 01:25 PM
  #69
BigRedRam95
https://dodgeforum.com/forum/2nd-gen...h-sticker.html
Old Apr 2, 2009 | 01:36 PM
  #70
brosnibean's Avatar
brosnibean
yes, those be them
