tires
Old Mar 29, 2009 | 10:05 PM
cricketg4's Avatar
cricketg4
Default tires
on my 94 i have 3 in blocks in the back with a 2 in leveling kit up front. could i fit 33x12.50 on it? and aint 285/75/16 the same as 33x12.50?
Old Mar 29, 2009 | 10:07 PM
dodge15004x45.9's Avatar
dodge15004x45.9
yea u can fit 33. 285 75 16 is 32.8 tall.
Old Mar 29, 2009 | 10:23 PM
Cereal Killer's Avatar
Cereal Killer
Yeah you'll be fine with either
285/75/16s are like 33x11.5
305/70/16s are 33x12.5s
Old Mar 30, 2009 | 06:34 AM
olyelr's Avatar
olyelr
Just FYI Dodges come stock with blacks in the rear. That me be what you have in the back... or do you have 3" blocks on top of the factory block? That would look a little funky with only a 2" spacer in front
Anyway, as far as tires go you should be fine. But, if you get a 10" wide wheel with minimal backspacing you could very easily rub the rear corner of the front fender while flexing/turning.
Old Mar 30, 2009 | 12:18 PM
Cereal Killer
That's a good point.
However 12.5 inch wide tires will be fine on an 8" wide wheel, and with proper back spacing that should eliminate your rubbing worries.
Old Mar 30, 2009 | 11:29 PM
olyelr's Avatar
olyelr
Exactly, an 8" wide wheel would be a much better size than a 10" for that application.
Old Mar 31, 2009 | 06:11 PM
cricketg4's Avatar
cricketg4
ok guys thanks that helped out alot. im only 17 yrs old so i dont know a whole lot about vehicles. also, if i was gonna put 33x12.50 on it i will have to downsize my rim to a 15. will that mess anything up doing that? i was told something about the backspacing has to be the same or somethin
Old Mar 31, 2009 | 06:24 PM
dodge15004x45.9
Why u going 15's? Backspacing push yr tire out from the fender. So you can run larger tire and have no rub.
Old Mar 31, 2009 | 06:25 PM
Cereal Killer
You can get 33x12.5s on a 16 inch rim. They are generally cheaper for a 15" inch rim though. and since 1994 has a single piston caliper you can use 15" wheels. the later model dodges (2000 and up I think) had dual piston calipers and some people have clearance problems with them. That being said if you plan on upgrading your breaks you should stay at 16" also most 15" tires are C rated. So if you tow or haul there are alot more D and E load rated tires available for 16" wheels.
Old Mar 31, 2009 | 06:33 PM
cricketg4's Avatar
cricketg4
ok do you think i nedd 8" wide or 10" wide for the 12.50s? i know either on of em will fit. just askin ur opinion
