Tune up time
Old Apr 1, 2009 | 10:21 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by lastrights
dont go any smaller than 8mm on the wires
Why are trucks come with 7.5 mm right?
Old Apr 1, 2009 | 10:35 PM
PurplDodge's Avatar
PurplDodge
And why is that?
Old Apr 1, 2009 | 10:42 PM
Cereal Killer's Avatar
Cereal Killer
I think the stockers were 7mm
Old Apr 1, 2009 | 10:48 PM
aim4squirrels's Avatar
aim4squirrels
Thicker wires = less propensity for arcing and predetonation. Of course, a higher quality 7.5mm wire will beat an el cheapo 8mm wire. A general rule is the less ohmic resistance the better, as the electrical charge will take the path of least resistance and hopefully that's down the wire and not thru the insulation to another wire. With a cheap set of wires with bad crimps, it might be easier for the spark to jump to a less resistant wire, believe it or not.
Old Apr 1, 2009 | 10:59 PM
dodge15004x45.9
Most of the wires are 40-50 ohms.
Old Apr 2, 2009 | 12:51 AM
Cereal Killer
Originally Posted by aim4squirrels
You know,
Steve05Ram360 swears by the mopar performance cap. He thinks it held up better to his MSD ignition better than any other he tried. I been thinking about giving one a whirl as I'm running an MSD box too.
Dammit. Now i'm all conflicted again. Son of a bitch...
Old Apr 2, 2009 | 11:09 AM
steve05ram360's Avatar
steve05ram360
You know,
It worked better for me over the Accell cap & rotor. It lasted longer than the brass for some reason. My setup at the time was the MSD off-road box with the off-road coil, autolite 3923's, MSD 8.5 wires.
and beyond the ignition... 52mm fastman, crower 1.7 RR's, Modded kegger, gibson shorties into the stock y-pipe into a dual out flowmaster set to 2.25" (keeps low end torque up).
Old Apr 2, 2009 | 11:11 AM
steve05ram360
100% true... stock wires are 8~10k ohms & up/ft... the MSD's are 40~50/ft
Old Apr 2, 2009 | 11:17 AM
dodge15004x45.9
When should you replace plugs, wires, cap and coil?
Old Apr 2, 2009 | 11:37 AM
Cereal Killer
Alright. I think I'll give it a try. Mopar performance stuff seems to be quality in general.
Thanks for your input Steve.
