did the throttlebody mod
Old Apr 6, 2009 | 08:20 PM
dodge15004x45.9's Avatar
dodge15004x45.9
How it run now?
Old Apr 6, 2009 | 10:24 PM
J415's Avatar
J415
Originally Posted by RAZRAM
i got it shiny by just taking a little wire wheel for the dremel and going over the whole thing then hand polishing the area where i cut it. This is so easy to do if you have a dremel with a bunch of cut off disks and a sanding wheel attachment for the dremel. I suggest the ones that are considering doing it to just do it. Im 17 and got it done in under 2 hours and it looks great.
Why didn't you grind down that little nub in the middle of the 2 bores? I did it to mine and I still have one inch of thread left.
Old Apr 7, 2009 | 12:49 AM
cool breeze's Avatar
cool breeze
what exactly is the mod?
Old Apr 7, 2009 | 01:02 AM
J415's Avatar
J415
Do a search for poorman's tb and you'll find out.
Old Apr 7, 2009 | 01:16 AM
Jase's Avatar
Jase
http://dodgetruckworld.tenmagazines....erformance_mod
Old Apr 7, 2009 | 01:52 AM
ophidia's Avatar
ophidia
It didn't make any noticeable difference on my truck, other than changing the intake note a bit when you get into the throttle. I was a fun little project, though. Something to do on a boring afternoon this past fall.
Old Apr 7, 2009 | 03:01 AM
TIMIDONE's Avatar
TIMIDONE
I did the throttlebody mod and im very pleased. It turned out well and the increased performance is noticeable. Took me about an hour and a half to do it. Check it out
What size of drummel you use?
Old Apr 7, 2009 | 03:08 AM
magnethead's Avatar
magnethead
I have a 3.9 in my dakota..gonna put a stock 5.9 TB on it...then maybe take back off and port it out sometime down the road. Only difference, I'll be using and air die grinder and bit. Anything going to be different between the dremmel and diegrinder that I should note?
Old Apr 7, 2009 | 03:59 AM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by 99DRAM31887
yea its aftermarket cuz this is my second, 2nd gen and my other one just had v8 on the tb and this one has holley stamped on its left side
When I installed my Fastman 52mm TB, I believe my old one had "Holley" stamped right in the left front. Not sure if they were always made by Holley, but the later model years certainly were.
Show us some pictures, we'll be able to give you a good opinion whether its original or aftermarket.
Old Apr 7, 2009 | 08:44 AM
engineblock's Avatar
engineblock
can someone put the tb mod in the DIY or can someone give me the exact location on to where it is if its already made. I tried searching for it but no luck
