2008 ram wheels work on a 96?
Old Apr 7, 2009 | 09:42 PM
CRNA's Avatar
CRNA
Default 2008 ram wheels work on a 96?
Is the bolt pattern the same for a 2008 2wd ram as a 96 ram 2wd? If not isnt there a wheel adapter kit? I found some 2008 ram 20" wheels and tires that would look nice on the 96
Old Apr 7, 2009 | 09:48 PM
engineblock's Avatar
engineblock
post a pic of the rims ill tell you if they fit, i have the chrome rims from a 2003 on my 95
Old Apr 7, 2009 | 10:01 PM
CRNA's Avatar
CRNA
Old Jun 24, 2009 | 11:34 PM
owenator08's Avatar
owenator08
Default Bolt pattern for an 2008 1500
Can anyone tell me what the bolt pattern for a 2008 ram 1500 is i have looked all over and cant find it.
Old Jun 24, 2009 | 11:35 PM
speeddemon31176's Avatar
speeddemon31176
The same as all the previous years all the way back to the 94's for sure.
Old Jun 25, 2009 | 05:32 PM
owenator08's Avatar
owenator08
k, thanks for the info.
Old Jun 25, 2009 | 05:50 PM
PurplDodge's Avatar
PurplDodge
They'll fit.
Old Jun 25, 2009 | 08:49 PM
dodgeram07's Avatar
dodgeram07
and yes they have the same bolt pattern.. 5x5.5
Old Jul 22, 2009 | 12:03 AM
r6roadracer's Avatar
r6roadracer
THe bolt pattern is the same, but the lug size and offset is not. They are both 5 lug by 5.5" bolt circle. However, the older rims I believe are 25mm offset and the newer rims are 30mm offset. The old lugs are 1/2" and the newer lugs are 9/16".
So...
Due to the offset, your wheels will sit inwards 5mm on each side.
And, you will have to use your 1/2" lug nuts on rims designed to work with 9/16" lug nuts. The mating surface area is likely going to be different (probably less).
I have talked to some people that have done it and it looks like some here already have, but I would be cautious that you really take a close look at the surface where the lug nut engages the rim. I'd even go so far as to blue an old rim and a new rim at the lug nut mating surface and install them both with the 1/2" lug nuts and see what kind of mating surface you get by comparing the wear band you'll create. I am guessing the mating surface on the newer rims with the 1/2" lug will be much narrower than on the original rims. But I dont know for sure.
If something goes wrong it could get ugly really fast at 80MPH on the highway.
Old Jul 22, 2009 | 07:50 AM
anesthes's Avatar
anesthes
What year was the major change ?
I have a 2000 ram. Could I put rims from a 2002 for example on mine, or is the stud diameter different as well?
-- Joe
