2wd lift
Old Apr 22, 2009 | 12:56 AM
  #21
dakotas ram's Avatar
dakotas ram
i ordered these yesterday......anyone used them before?.....not expecting them to last too long, but ill see
http://cgi.ebay.com/ebaymotors/ws/eB...B:EOIBSA:MT:11
Old Apr 22, 2009 | 01:00 AM
  #22
Viper37's Avatar
Viper37
Originally Posted by ram1wheelpeel
from what i gathered any type of spacer/coil lift on a 2wd greater than 2.5 inches you need new upper control arms to gain proper alignment/ full range of suspension travel.
No.
You wont need new upper arms, you will however need to grind your bump stop perch and install limit straps to prevent your spindles from hitting your perch's.
Old Apr 22, 2009 | 01:21 AM
  #23
dakotas ram
so i can go 3" in the front?.....the limit straps keep from over travelling and doing what?
Old Apr 22, 2009 | 01:24 AM
  #24
Viper37's Avatar
Viper37
re-read the post.
  #25
dakotas ram
never mind, i just found it, they limit the shocks........what all do you have on your truck?
Old Apr 22, 2009 | 01:26 AM
  #26
Viper37's Avatar
Viper37
No, they do not limit the shocks. The Shocks are not the problem. Your spindles will hit your bump stop perch if you do not grind the perch back.
Grind the perch, install longer NITROGEN shocks to regain ride quality, and install limit straps.
Old Apr 22, 2009 | 01:36 AM
  #27
dakotas ram
oh, well i searched and found a pic where it was bolted to the shock bolts.....do you have any pics?.....
Old Apr 22, 2009 | 01:41 AM
  #28
Viper37's Avatar
Viper37
Show me the pic, because that's so sketchy.
https://dodgeforum.com/forum/2nd-gen...installed.html
Old Apr 22, 2009 | 01:45 AM
  #29
dakotas ram
http://www.4x4wire.com/toyota/4Runne...ion/steve9.jpg
Old Apr 22, 2009 | 01:47 AM
  #30
Viper37's Avatar
Viper37
That is so scary.
