battery leak at terminal
Old Jan 10, 2010 | 12:39 AM
jasonw's Avatar
jasonw
Site Moderator
No, it will not hurt anything to go over the stock amp rating.
http://www.batteryfaq.org/
Check out that link to figure out which brands are actually made by what companies. It can get rather confusing, but according to that list and what I've researched, Walmart's "higher end" batteries are actually made by a good company.
Old Jan 10, 2010 | 12:46 AM
Laramie1997's Avatar
Laramie1997
Unless varying by location, they sell Ever Start, which is a good brand unless you have a lot of audio equipment.
Stock CCA is 650, and I run 1000CCA.
Old Jan 10, 2010 | 12:51 AM
dakotas ram's Avatar
dakotas ram
cool, so i should ge the maxx?
jasonw's Avatar
jasonw
Site Moderator
IMO, yes.
Old Jan 10, 2010 | 01:25 AM
95MaroonMonster's Avatar
95MaroonMonster
my battery has like 850 CCA iirc (the 1000 cca battery at Rural King wouldn't fit in my battery tray and cost a lot more)
Old Jan 10, 2010 | 03:30 AM
Laramie1997
Yea, you'll do fine with them. You only have the one amp, don't you?
I know we run the same battery I have in our 2004 and it does great. I on the other hand, replace mine ever 60 days because I normally blow a cell in them by that time. There is nothing wrong with the charging system, but I like to have tunes when I'm working on the truck or working around it.
Old Jan 10, 2010 | 04:25 AM
Sheriff420's Avatar
Sheriff420
my oem battery was only 600 cca and the everstart maxx is 875 cca.
laramie, every 60 days? you're lucky you haven't been blacklisted for all the returns yet.
have you thought of getting one of those capacitor deals that looks like the plutonium canister from back to the future? are they even worth the trouble?
Old Jan 10, 2010 | 07:10 AM
halfamil's Avatar
halfamil
Walmart guide had 2 different ones for my model that were the same price,$65 1 month ago.I got the Everstart MAXX 27-N 900ca 750cca.I glanced at them Friday while purchasing oil,and the MAXX 27-N was $75.I said outloud,"Damn,went up $10" They do have a $10 rebate if you return your old one.
Old Jan 10, 2010 | 12:37 PM
Laramie1997
Not really worth it on my build. Those are for major builds like 3000+ watts. Their purpose is to keep a constant volt rate to the amps instead of varying like battery alone gives you. The variation robs you of some power, and that's about it. On large builds, you need all the help you can get. Since I only have a total of 2300 Watts spread out amongst three amps, I don't see it being worth my time. If I were competing, I'd have one in the works.
I used to work for Walmart, and they really don't care as long as the battery tests dead. It's Ever Start's issue then. Everyone at the store I take it to knows me, so if ES ever did have a problem with me bringing it in, the management would just ignore it.
Old Jan 11, 2010 | 03:19 PM
dakotas ram
alright i got a maxx-27s cca-750 and ca-860....thats the biggest one i found that would fit in my truck, my old one is a duralast and it was about 4 inches shorter than this one, it was cca-600 and ca-750....apparently ive been needing this for awhile, didnt know it could sound this good starting another good thing is i had an old battery out in the garage that was still under the prorate so i got this new one for $35 and i get to keep mine out of the truck since its still fairly good
