ATF+2 or ATF+4
Old Apr 27, 2009 | 06:55 PM
atc250r's Avatar
atc250r
Default ATF+2 or ATF+4
Will be getting my trans flushed shortly ('97 4x4) and just wonder why everyone hear talks about using only ATF+4. The manual just calls for +2.
Old Apr 27, 2009 | 07:39 PM
dhvaughan's Avatar
dhvaughan
Your owners manual probably calls for a 7176 or ATF+3. both of those have been superseeded by ATF+4. All are synthetic and its the only thing you should use in your transmission. If your shop tells you they have "universal" or "additive" or some other bull$hit then you need to show them the owners manual and tell them to either use that (ATF+4) or nothing. if its a problem then buy it and take it to them. beware, its expensive.
dexron/mercon 3 is NOT the same thing as ATF+3 nor ATF+4
Old Apr 27, 2009 | 08:13 PM
EndIsNear's Avatar
EndIsNear
I was told to use ATF+4 no matter what. I researched a little, and this is what I came up with. I was also told to not use synthetic either because our transmissions weren't built for sythetic fluid?? Correct me if I'm wrong, somebody at work told me that.
Old Apr 27, 2009 | 08:36 PM
hometheaterman's Avatar
hometheaterman
Mopar ATF+4 is all I will use. Some guys like Amsoil though but I see no reason as the Mopar is proven to work and already a synthetic. BTW Wal-Mart sells Mopar brand transmission fluid or at least used to for a ton cheaper than the dealer and it was the same thing. It was like $4 or $5 a quart vs $11. I haven't bought any in a while.
Old Apr 27, 2009 | 10:35 PM
aim4squirrels's Avatar
aim4squirrels
Use the ATF+4 ONLY, and stop second-guessing yourself.
Chrysler phased out all ATF+2 and +3 years ago in favor of ATF+4
DO NOT use Type F, Dexron, Mercon III or V, or Universal ATF.
Old Apr 27, 2009 | 10:57 PM
ophidia's Avatar
ophidia
I think the ATF +4 (Wal Mart brand) is 4-5 bucks a quart. I just bought some a month or so ago when I changed the fluid in my xfer case.
Old Apr 28, 2009 | 03:55 PM
PurplDodge's Avatar
PurplDodge
Dont be afraid to use an "off brand" ATF+4. It is the same stuff as Mopar ATF+4.
http://www.centerforqa.com/licensedatf4brands.html
Old Apr 28, 2009 | 03:57 PM
Bob5151's Avatar
Bob5151
Yeah, when I replaced my governor pressure sensor in my '01, I found Mopar brand ATF+4 at WalMart for like $4.69 a quart, not too bad.
Old Apr 28, 2009 | 04:01 PM
PurplDodge's Avatar
PurplDodge
Coastal ATF+4 @ my local AutoZone is $3.00/quart.
Old Apr 28, 2009 | 05:20 PM
ophidia's Avatar
ophidia
I found my receipt and my Super Tech ATF+4 was 3.93/qt. Not too bad. Fortunately the quality of the ATF is higher than the sawdust and bootleather dog food they sell. :B
