More lift?
Old Apr 29, 2009 | 01:52 PM
  #21
Hoss98's Avatar
Hoss98
no Im just gonna doin a coil spacer in the front. something like what Aubrey was saying. The tires fit its just when you hit a bump while you turn they rub in the front so I just need to rais the front a little and the truck should sit nearly lever front to back after that.
Old Apr 29, 2009 | 01:59 PM
  #22
dodge15004x45.9's Avatar
dodge15004x45.9
You should look it adjustable ones incase you ever want to move up to 5"?
Old Apr 29, 2009 | 02:04 PM
  #23
Hoss98's Avatar
Hoss98
I should have dont that in the first place but I already payed for and put on the 3" and I really dont wanna change it. Plus I really can afford to go over 35" tires cause of the expensive tires and gas running them on a daily driver like this so there would be no point to go to 5". If i really need to I can get a leveling kit which raises the front something around 2" and the either do blocks to rais the rear or the same ad-a-leafs as 5" lifts use.
Old Apr 29, 2009 | 02:25 PM
  #24
dodge15004x45.9
Wait you have a 3" lift on there now where will you be puttin A 2" spacer at?
Old Apr 29, 2009 | 04:33 PM
  #25
Hoss98's Avatar
Hoss98
Coil spacers in the front coil springs. Like a leveling kit. Only if i do 2 in I will have to either block the back up or add more leaf springs cause the front will ride higher than the back if I dont. But I would do 3/4 inch or 1 inch in the front and it would probably sit level.
Old Apr 29, 2009 | 05:10 PM
  #26
Aubrey's Avatar
Aubrey
I'm pickin up what you're layin down. I smell what you're cookin.
