bought a 01 ram. winding noise in reverse?
Old May 14, 2009 | 11:32 AM
  #21
lv360ram's Avatar
lv360ram
Excellent explanation by Silver - saved me alot of typing.
Sonnax makes some parts that are supposed to reduce that noise but they didn't work for me.
Old May 14, 2009 | 12:04 PM
  #22
fjmg's Avatar
fjmg
Yes excellent explanation, the design requires almost triple the psi in reverse. One mopar tranny rebuilder actually told me that if you want to minimize any problems with the reverse clutch seals then park the truck at night in such a way so that you need to put it in drive to leave first thing in the morning (primarily when its cold, sub freezing). That way you are not asking the seals in the reverse clutch to hold back almost 300 psi when they are 20 below.
Old May 14, 2009 | 09:23 PM
  #23
townsley4's Avatar
townsley4
hey thanks for the info. i appreciate it. yea i hope its nothing like a crack hose or seal or soemthing...the mecahnic at the dealer had told me that it was low on transmission fluid and that is why it made that noise...but it still maks that noise in reverse. i think he was just b.s.ing.... im supposed to take the truck back to teh dealer monday to have them look at it AGAIN for the 5th time....
Old May 14, 2009 | 09:59 PM
  #24
Silver_Dodge's Avatar
Silver_Dodge
Take the TSB with you this time and show them.
Old May 14, 2009 | 11:00 PM
  #25
townsley4's Avatar
townsley4
tsb??? wat is that?
Old May 15, 2009 | 12:20 AM
  #26
Silver_Dodge
Read my previous post. I posted a link to the TSB (technical service bulletin). Print it and take it with you.
Old May 15, 2009 | 04:03 PM
  #27
townsley4's Avatar
townsley4
But my truck is an 01, that tsb only goes to 99' rams. if i take that to the dealer that is what they would say to me because they are rippoffs. but ill try....you dont happen to see any for a 01 ram?
Old May 18, 2009 | 03:11 PM
  #28
Silver_Dodge
I thought I saw a similar TSB for '00-'01 too. I can't find it now.
Did you take it back in yet?
Old May 18, 2009 | 04:06 PM
  #29
mgv357's Avatar
mgv357
Cool Reverse noise
I put Lucas transmission fluid in mine and it quit making noises and shifts better. Might give it a try.
Old May 18, 2009 | 08:00 PM
  #30
jasonw's Avatar
jasonw
Site Moderator
Lucas? I think you mean the Stop Leak or whatever?
The only transmission fluids that should ever be used in our transmissions are Amsoil or ATF+4. Anything else will 99% of the time cause problems and fry our transmissions. They are very picky like that.
