P1494 after i put on a 14x3 air cleaner
Old Apr 30, 2009 | 03:52 PM
01dabram20's Avatar
01dabram20
Default P1494 after i put on a 14x3 air cleaner
Why am I getting a p1494 code after i put on the new air cleaner?
Old Apr 30, 2009 | 04:01 PM
wjxavier's Avatar
wjxavier
try resetting the pcm. it might be throwing a code because of the possible increased air flow and the pcm is having hard time adjusting everything? idk could be wrong, just throwing it out there
Old Apr 30, 2009 | 05:43 PM
jasonw's Avatar
jasonw
Site Moderator
+1, try resetting the PCM. See if the code comes back. After an upgrade or modification like that, usually its a good idea to reset the computer so it can start from scratch and relearn how to use the increased air flow.
P1494 is a code for "Leak Detection Pump or System". Basically, the computer thinks something is wrong with the fuel tank, fuel lines, carbon canister, gas cap, vacuum lines, or fuel pump/filter.
Did you remove any hoses in there and not reattach them?
Old May 1, 2009 | 08:35 AM
01dabram20's Avatar
01dabram20
I attached all the lines that i took off. the only ones I took off was the one by the map sensor. and the map sensor but I put those back on.
Old May 1, 2009 | 05:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Why did you remove them to do the air cleaner? Remove them again and make sure there is no broken contacts inside the plugs or the sensors themselves. And that the wires going into the plugs are not loose or broken off the contacts inside the plug.
Old May 2, 2009 | 02:31 AM
01dabram20's Avatar
01dabram20
I removed it to clean the throttle body.
Old May 2, 2009 | 02:59 AM
jasonw's Avatar
jasonw
Site Moderator
When you put the air cleaner back on, did you leave that ring (gasket) on? It goes between the air cleaner assembly and the TB, helps make a nice seal.
Old May 2, 2009 | 07:51 AM
aim4squirrels's Avatar
aim4squirrels
tighten up your gas cap.
you can run a thin film of motor oil on the rubber seal to get a better seal.
