HO**Y C**P I need help
Old May 4, 2009 | 08:36 PM
Erik Kuijvenhoven's Avatar
Erik Kuijvenhoven
Default HO**Y C**P I need help
So i was a little low on oil and my truck is making a ticking noise when she idles not a very fast but deff a tick is there,,, then on top of that my OD when engaged is shaking my truck vigorously if i turn it off it's OK so guy's what do u think is my engine tick a cam or my valve's or something i dont know and is my tranny in need of a rebuild or is there some magic sensor I can replace lol I WISH anyways until I get some input ill be crying and kicking myself in the head for not checking my oil in the last 3 weeks and not doing my tranny fluid for 15,000 Im just so busy trying to keep my wife happy and running a construction business and changing diapers ... anyways im gonna go get a beer
Old May 4, 2009 | 10:49 PM
dhvaughan's Avatar
dhvaughan
have a beer you need one.
did you fill it back up with oil yet, and its still noisey ? add a pint of STP.
why is your truck using oil ? plenum ?
does the OD shudder ease off at high speed?
if so, just run with OD off.
if it shudders at higher rpm too, then you got a problem.
i don't know, we need montec back... where'd he go anyway. i guess he got tired of answering endless trasnsmission questions. haha
Old May 4, 2009 | 11:29 PM
Laramie1997's Avatar
Laramie1997
Check your tranny fluid. Mine will have a tick like that when it starts getting low on fluid.
Old May 5, 2009 | 03:57 PM
divetruck's Avatar
divetruck
Every time you get gas check your fluids under the hood. Just have to make it a habit
Old May 5, 2009 | 06:03 PM
95MaroonMonster's Avatar
95MaroonMonster
for some reason, my tranny's been fine after all the towing and hell i put it through
now that i say that, its gonna die tonight
Old May 5, 2009 | 07:57 PM
RPU's Avatar
RPU
It depends on the miles and how you treat the truck. Lifter's do have some issues with time. I agree with the STP. that will let u know if ya got other problems. Change the tranny fluid on the truck and see what happens with the OD. Doubt the ticks are coming from the tranny though.
Old May 5, 2009 | 08:12 PM
MSAL619's Avatar
MSAL619
The ticking...cant help sorry. But what is going on with the trans? Ive got a 95 5.9 and when i would reach crusing speed, the truck would down shift and the truck would shake like hell until i gassed it or let off the pedal, then it would come back. I drove around like that for months (trans still works, thank God) thinking it was a torque converter. My buddies dad whos a mechanic for Ford checked under my hood and noticed that I had a melted spark plug wire. We replaced that wire and no more shaking!!! i couldnt believe it. trucks been running fine for about 2 months now. maybe check out the wires
Old May 10, 2009 | 02:29 PM
Erik Kuijvenhoven
Well I was driving on the highway towing with OD off doing about 4300rpm and I had the oil level a bit below add mark .... I cant believe that it put this tick into my engine One guy I know John with a dodge said it was a collapsed valve for sure, I really don't know, but I changed my oil/filter and added a liter of Lucas oil additive ,, I think my engine sputtering making the crazy vibration was a bad plug One of my plugs was really messed up so i replaced all my plugs with Champion's. instead of ****ty Bosch!!!!!!!!!! but my truck still Idles funny My buddy John told me to take my valve cover off and pour oil on my valve's it might unstick the collapsed valve.. anyone know this trick ???? or is he just talking lol Thanks
Old May 11, 2009 | 09:38 PM
Erik Kuijvenhoven
So I got my tranny fluid changed and its still quite black anyone rcomend me doing a partial dchnage again in about 5 000 miles ???? or will new filter clean that oild fluid up so ill be good for another 15 000??? Thanks
Old May 11, 2009 | 09:42 PM
ophidia's Avatar
ophidia
My engine has a rhythmic tick as it idles. It's the fuel injectors-- it became more noticeable when I ripped off the disintegrating under hood insulation. Where does it sound like it's coming from?
