check engine light
Old May 5, 2009 | 01:17 PM
hirschy's Avatar
hirschy
Default check engine light
The check engine light came on, and I checked the code and now I'm confused. please help. This is what it came up with when I checked the code 34355. I know 34 means (Speed control circuit or
speed control switch
always low or high.) and the 55 means end of code. So what does the middle 3 mean cause it says codes are only two numbers. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
thanks,
jeff
Old May 5, 2009 | 01:34 PM
wjxavier's Avatar
wjxavier
you had to have read it wrong. there would be no other way i think
Old May 5, 2009 | 01:48 PM
hirschy's Avatar
hirschy
I read it several time and I said the same thing. I'll have to go check again next time I'm outside.
I went out to check and I think it might be.
code 12(which makes sense cause I changed the battery)
and code
code 43(Ignition coil circuit #)
sorry I probably read it wrong the first time.
Old May 5, 2009 | 04:09 PM
Laramie1997's Avatar
Laramie1997
Your not looking in the correct computer range. Being a 97, your truck is obdII.
Old May 5, 2009 | 04:13 PM
hirschy's Avatar
hirschy
Isn't 97 one of the weird year where its half *** obdI and obdII? so the link I posted at the top incorrect?
Old May 5, 2009 | 04:21 PM
Laramie1997
When was your truck built?
Mine was a March model...
Old May 5, 2009 | 04:28 PM
hirschy's Avatar
hirschy
Where does it say?
Old May 5, 2009 | 04:32 PM
cricketg4's Avatar
cricketg4
open you driver side door and there should be a sticker in there that has your vin number on there and stuff and it should tell you there
hirschy's Avatar
hirschy
I checked the inside of the driver door and it said 10-96 so october.
Old May 5, 2009 | 04:35 PM
hirschy's Avatar
hirschy
thanks cricketg4,
I totally forgot then I remembered the tag on the door.
