1/2 Qt in 3000 miles
Old Jan 5, 2011 | 10:04 PM
  #21
dodgeram07's Avatar
dodgeram07
i wouldnt worry, 4000 miles your due for a oil change alway
a bad pvc could blow alot of oil,,, what brand is your pvc?
also i just redid my plenum gasket is was leaking again so i would check that again
Old Jan 5, 2011 | 10:07 PM
  #22
BigRedRam95's Avatar
BigRedRam95
I go 6000 Miles on the synthetic oil. Its the original pvc 83000 Miles on it. Did you do the Hughes kit on your plenum?
Old Jan 5, 2011 | 10:10 PM
  #23
How many miles on your truck? Look in your PCV hose, any oil in there?
My truck was going thru THREE quarts a WEEK.... (less then 200 miles a week....) before the plenum replacement. After, I was still doing a quart a week..... replaced my crappy aftermarket PCV valve, with one from the dealer..... oil consumption dropped thru the floor. (and I know where it is going, still need to change my valve cover gaskets.)
My truck has 165K on it.
Old Jan 5, 2011 | 10:15 PM
  #24
BigRedRam95
My truck has 83,000 Miles on it.
Old Jan 5, 2011 | 10:23 PM
  #25
I would think plenum, or aftermarket PCV then.
Old Jan 5, 2011 | 10:41 PM
  #26
dodgeram07's Avatar
dodgeram07
yep sure did, and it blew
Old Jan 5, 2011 | 11:38 PM
  #27
UnregisteredUser's Avatar
UnregisteredUser
Hit the dealership, drop five bucks on a new PCV valve.
Old Jan 6, 2011 | 06:36 AM
  #28
BigRedRam95
I will try the pvc first I think it is probably time to replace the pvc anyway it is from 95.
Old Jan 6, 2011 | 02:12 PM
  #29
BigRedRam95
So there should be no oil in the pvc hose right
Old Jan 6, 2011 | 02:14 PM
  #30
Very little if any at all.
