Frozen Caliper/Shaking
Old 05-09-2009, 09:00 AM
Gtram43's Avatar
Gtram43
Gtram43 is offline
Default Frozen Caliper/Shaking
Im pretty sure I have a frozen caliper, after driving for a few minutes, noticed the rotor is very hot( could fry an egg on it), drove it a few more times and after using brakes for a few times I get wobble when going more than 30 mph, sometimes the caliper frees up and wobble goes away. My question is, is it likely I have to change the rotor as well as the caliper since it may be warped?
Old 05-09-2009, 09:51 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
You might be able to have the rotor turned if it's not too far gone.
Old 05-09-2009, 10:05 AM
Gtram43's Avatar
Gtram43
Gtram43 is offline
Thanks for the quick reply. Would a sticking caliper cause this wobble or do you think it could be the combo of the rotor warp and the caliper. I dont mind changing both since Ill be there anyway but I guess what Im after is could this intermittant wobble be caused from the caliper.
Old 05-09-2009, 10:13 AM
zman17's Avatar
zman17
zman17 is offline
The caliper sticking creates a lot of heat, which in turn warps the rotor.
Old 05-09-2009, 10:24 AM
Gtram43's Avatar
Gtram43
Gtram43 is offline
Thanks, nice truck and dog by the way.
Old 05-09-2009, 10:36 AM
zman17's Avatar
zman17
zman17 is offline
NP and thanks to you.
Old 05-22-2009, 09:01 PM
Gtram43's Avatar
Gtram43
Gtram43 is offline
Default update on brakes
ok, here are the changes i made, new caliper, new rotor, new pads, bled line and have a good peddle. Problem is the damn thing is heating up again and smoked a bit. What else could make a new caliper as well as the old one stick open? Someone told me I should re[lace the rubber brake line as sometimes they collapse and dont allow fluid to go back to release caliper piston. This seems to make sense but how would I know if its simply the rubber line or the entire line? The entire line seems like a big job. What do you guys think it could be?
Old 05-23-2009, 05:46 AM
zman17's Avatar
zman17
zman17 is offline
You heard right about the rubber line. I doubt the steel line is bad.
Old 05-23-2009, 07:01 AM
Gtram43's Avatar
Gtram43
Gtram43 is offline
Im replacing that this morning. I didnt test drive it more then a mile so I hope the heat didnt cause any damage but I was surprised how much it heated up in that distance. Once again, thanks.
Old 05-23-2009, 01:20 PM
Linustratus's Avatar
Linustratus
Linustratus is offline
So what is it that you get, some sort of braided line or what? Im definitely interested in this, Id like to run that **** to all 4 corners, my brake lines are rusted so bad.
Quick Reply: Frozen Caliper/Shaking
