408 stroker ram project
Old Sep 2, 2009 | 04:41 PM
  #171
jbomb's Avatar
jbomb
Thanks bigdodge99
Yeah then the white one is the vacume then.
My 318 intake that came out of my 4x4 truck has 3 vacume ports on the passenger side.
I used the 360 intake off a 97-98 motor I bought but relised that it has 2 vacume ports on the passenger side. The sticker on the radiator cross support says that a vacume line goes to the front axle when equiped with 4x4. This makes me think that the 360 motor I bought came out of a 2 wheel drive truck. Interesting.
Old Sep 6, 2009 | 07:08 PM
  #172
jbomb's Avatar
jbomb
Been busy working on the truck all weekend. So I will post some pics when we get back from the pool hall on our bikes.
Pulled the motor out and fixed the water leak in the rear of the intake. Put it all back together and fired her up! I flashed the computer with my sct tune. It seems to be running way too lean by looking at the plugs. And the headers close to the heads seem to be running about 600 degrees with a temp probe. I dont have my fastman yet for the rear o2 sensor and my map sensor is used so thoes could be my problem. But the truck seems like the 318. I wonder if I diddnt load my flash program right or something. Well we have a lot of tuning to do. Chech all cables and linkages for adj. and check and change spark plug gaps. make sure all the injectors are working corectly ect. Well leaving soon so posting some pics soon and talk to ya tomorrow.
Old Sep 6, 2009 | 10:17 PM
  #173
jbomb's Avatar
jbomb
This is where I had to get the motor just to reach the temp bung on the back of the intake.
The weld on this little sucker leaked like a sive
Old Sep 6, 2009 | 10:20 PM
  #174
jbomb's Avatar
jbomb
Me trying to work on it.
Yeah as you can imagine that was a lot of fun.
Ok she is running here. At idle
Drove it about 35 miles or so and she never got over 170 degrees. It was 70ish outside.
Old Sep 6, 2009 | 11:00 PM
  #175
95MaroonMonster's Avatar
95MaroonMonster
bet thats gonna be fun truck to tool around in when ya got her runnin
Old Sep 6, 2009 | 11:06 PM
  #176
BigDodge99's Avatar
BigDodge99
I had the same kind of fun with mine. Thermostat wouldnt open at first start up. I had to change it before I could do break in. Watching the temp climb up to high is not good for my blood pressure. Where did you put the trans temp sensor. I need to get one of those.
Old Sep 6, 2009 | 11:54 PM
  #177
jbomb's Avatar
jbomb
will post a pick tomorrow
Old Sep 7, 2009 | 10:48 AM
  #178
jbomb's Avatar
jbomb
Default SCT help
Hey guys I downloaded the drivers for the sct programmer and installed them but when I plug my porgrammer into the computer nothing comes up and I cant even see it when i go into the my computer area. I need to emil my map back and forth. The sct site suck by the way.
Old Sep 7, 2009 | 11:34 AM
  #179
BigDodge99's Avatar
BigDodge99
you ned to open up your live load to see the tunes in the tuner.
Old Sep 7, 2009 | 11:42 AM
  #180
busaguy05's Avatar
busaguy05
You downloaded the Live Load DCX program? I found this web site helpful http://www.morepowertuning.com/howto_emailtunes.html. Scroll down to the DCX 9550 and it has a link for the software and instructions.
